Bed cover is leaking
Discussion in 'Tonneau Covers, Caps and Shells' started by taco.yota671, Oct 18, 2020.
  1. Oct 18, 2020 at 6:51 AM
    taco.yota671
    taco.yota671 [OP] Member
    Toyota
    2018 Cement Grey Tacoma TRD off-road
    What's the best bed cover? the bed cover that comes with the truck leaks.
  2. Oct 18, 2020 at 7:57 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    take it back to the dealer to get it fixed.
  3. Oct 18, 2020 at 8:03 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    The bed cover that comes with the truck is very sufficient if installed correctly and operated correctly. Make sure you hear the clicks when you close each section of the cover.
    RedWings44 and mchertel like this.
  4. Oct 18, 2020 at 8:42 AM
    WDproTrd
    WDproTrd Active Member
    19 TRD PRO BLK
    DIAMONDBACK.
  5. Oct 18, 2020 at 8:53 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Perhaps one day Rolex will make a cover that is water resistant down to 300 meters. Until then assume that all covers leak.
    The trick is to find where the water comes in from and how to manage it.
    If the water comes in from the cab corners, a bedmat may be all that is needed to keep cargo dry.
    If water comes in from the tailgate (likely) then a tailgate seal may eliminate.
    Chew likes this.
  6. Oct 18, 2020 at 9:12 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    When i had my OEM cover, i used an additional thin weather strip all around. Never leaked since then.
    I have now switched out to a Powertrax XR cover, love it. Some water gets in from the small crack in the tail gate, but nothing serious.
  7. Oct 18, 2020 at 9:32 AM
    kpinthebay
    kpinthebay Well-Known Member
    Hawaii ==>>SF Bay Area
    Then you'll have to build a relationship with an AD and buy lesser covers, only to get a chance of maybe getting a Diamondback in the future.
    haha, sorry Rolex joke.
  8. Oct 18, 2020 at 9:37 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Diamondbacks leak as well....I’ve got one...it leaks. Other people have reported leaks as well.
    Not a lot, but if it rains hard enough....you’ll get water.
  9. Oct 18, 2020 at 9:47 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Every bed cover will "leak" and non of them, that I've read, claim to be water proof. They provide water resistance, cover your goods from prying eyes, and that's pretty much it. For the OEM, as mentioned, you need to make sure you hear the double-click. Also as mentioned, adding a small DIY weather strip under the edge of the cover also helps. Beyond that, each manufacturer has different weights, functionality, style, security, ect.
    BillsSR5 and RedWings44 like this.
  10. Oct 18, 2020 at 9:57 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    My OEM one seals pretty good. I just have to ensure all the latches are latched and there's no play. It can be tricky, but is doable. It gets easier when you realize where you need to press and how hard.
  11. Oct 18, 2020 at 10:21 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    4 runner
    El Duderino, Chew and IOPmanual like this.
  12. Oct 18, 2020 at 1:42 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep. I've had my oem tonneau cover though several good thunderstorms, a few rain storms, and a tropical storm that did quite a bit of damage this summer...had no serious leaks, just some wetness inside the diver side bed wall from that tropical storm when the wind was driving heavy rain sideways from the east.
  13. Oct 18, 2020 at 1:49 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Ridgeline
  14. Oct 18, 2020 at 2:05 PM
    The_Devil
    E
    That is one hell of a mod
    El Duderino likes this.
  15. Oct 18, 2020 at 9:56 PM
    Rainoffire
    He did say unlimited budget.
