Bed Covers and MPG
Discussion in 'Technical Chat' started by HawaiiTRD, Jun 5, 2013.
  1. Jun 5, 2013 at 7:08 PM
    HawaiiTRD
    HawaiiTRD [OP] "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    How's it going TacomaWorld!
    So I've been in an argument about Bed covers helping MPG. It started when a friend mentioned their 4Runner gets better MPG than their Taco. His explanation was that the Taco gets drag from wind hitting the tailgate. My explanation is that the 4Runner has the Duel VVT-i which helps (I'm actually not sure if the Tacomas have this now too). My friend says if I get a bed cover my MPG would be higher like his (in the 20's, I'm averaging a little over 18). I've heard that the tailgate helps build a "vortex" of wind in the bed that helps lighten the truck or something like that. I've actually witnessed this "vortex" thing from seeing leaves flying around in the back in a circular motion. I didn't think a bed cover would make a difference.
    Anybody have more knowledge that helps? Is my friend right about the wind drag? Are we both wrong?
    Anybody have a bed cover and noticed an increase in MPG?
    And can anybody confirm the Duel VVT-i helps the 4Runners or am I wrong about that?
    Thanks for any info
  2. Jun 5, 2013 at 7:20 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Mythbusters did a thing on the tailgate open or closed for better MPG's, and there was no difference. The vortex doesn't make the truck "lighter", it just kinda shoots the air over the tailgate, so cover, tailgate down, etc... Makes no change.
  3. Jun 5, 2013 at 7:24 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    I heard about the Mythbuster's episode that did it but I never saw it. That makes a lot more sense though that the vortex shoots air over. Thanks
  4. Jun 5, 2013 at 7:41 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :thumbsup:
  5. Jun 13, 2013 at 2:07 PM
    josher818
    josher818 New Member
    Jose
    Panorama, CA
    2012 Tacoma Double Cab
    Lifted, BAK Tonneau Covers, BAKFlip and Roll-X,
    My buddies were talking about it and It may not save your MPG but it will make it more aerodynamic. Even though the beds already have premade holes that allow the air to easily circulate, by covering your bed you do allow a better air flow giving you a a little extra "Oomff" in your ponies. LOL
  6. Jun 14, 2013 at 3:54 AM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    I have read scientific material, which I cannot find the link now
    and a toneau cover will help your MPG.
    I am putting mine back on this weekend and should know within 2 weeks. I "expect"
    .5 to .75 MPG improvement while driving 70MPH. Will update.
    I have a 98-4Cyl Manual. A 6-cul auto should be less improvement.
  7. Jun 14, 2013 at 3:58 AM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    I had my taco for about 3 months before I got my leer cap, back then I tracked my mileage with fuelly pretty closely. I saw no change at all, better or worse
  8. Jun 14, 2013 at 4:00 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    It is a fine line. You are adding weight but making it more aerodynamic. IMHO I think/believe a reg tonneau cover helps but as you get into the hard fiberglass covers it is a wash or worse
  9. Jun 14, 2013 at 5:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It all depends.....
    On my 96 tacoma, I saw a marginal (1-2mpg) increase with a bed cover (soft cover).
    On my 2007, I have not seen any increase (soft cover).
    Definitely not anything to brag about because its like slicing hairs.....
  10. Jun 14, 2013 at 6:32 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    Looking forward to your update :popcorn:
    I also thought about the weight of the cover and tried using it as an arguing point. In the end neither of us believed the other haha
  11. Feb 3, 2014 at 11:10 AM
    brackish
    brackish Member
    frank
    Tupelo, MS
    07 Prerunner
    I added a soft cover at about 15K miles, not for additional MPG but because I needed waterproof bed storage. I had been keeping a post break in MPG spreadsheet and had about 25 tanks on it when I installed the cover. After having it on for about another 25 tanks, the average difference in the MPG was .4 MPG improvement. This is across seasons with all types of driving both pre and post. 2007 doublecab prerunner
  12. Feb 3, 2014 at 11:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had a double cab short bed and did not calculate any noticable difference between having an open bed and having a tonneau. I did notice my MPG's were better with a shell though by about 2 MPG consistantly.
  13. Feb 3, 2014 at 6:35 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I get .5-2mpg better with my 13 DC TRD sport with a 6 speed. The tonneau is a Lund genisis elite. Myth busters test results lowering the tailgate makes no difference in mpg hasn't been my experience owning trucks for 40yrs. My gas mileage savings is no myth! Hope this helps.
  14. Feb 3, 2014 at 9:58 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    +2MPG with a shell is awesome!
  15. Feb 3, 2014 at 10:03 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I just added a shell and MPGs jumped from 17.3 to 18.7. Needless to say I'm pleased
  16. Feb 3, 2014 at 10:04 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    Seems like the soft covers are the way to go for better MPG.
  17. Feb 3, 2014 at 10:07 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    I would have thought for sure the shells would be the worst for MPG, considering the weight. Good for you though man, the extra mile per gallon makes a difference :thumbsup:
  18. Feb 4, 2014 at 3:51 AM
    mdcmn7
    Chuck
    East Coast
    My dclb saw no noticeable difference with my leer cap. Maybe weight offset aerodynamics?
    Aulthough it does handle better in the snow with it
  19. Feb 5, 2014 at 6:27 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    Since you're on the East Coast the added handling in snow is great. Plus you saw no noticeable difference so you didn't lose MPG either. Win Win :D
