Bed Covers (No Drill)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MightyMouse4, Dec 16, 2022.
  1. Dec 19, 2022 at 8:28 PM
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    The absolute easiest one to take on and off is the Lomax. I haven't purchased one yet but have to make a choice soon when my truck comes in. A standard Lomax Urathane is at the top of my list. It's in the low $800 range which is less than the Bakflips and Undercovers.
  2. Dec 19, 2022 at 8:31 PM
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    Go for a Lomax. Super low profile, looks amazing, and you are correct it is super easy to open/close and remove if needed. Very pleased with mine.
  3. Dec 21, 2022 at 7:11 PM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    One bolt the rest are locks released though handles, then it lifts off, I've been told it weights around eighty pounds, but I never weighted it. I can handle it by myself but it can be a challenge.
  4. Dec 21, 2022 at 8:16 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    It helps to have two people when removing the cover, but doable with one person. I installed solo.
    Great design, you shouldn’t be disappointed.
  5. Dec 22, 2022 at 4:09 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I had the OEM Soft tri-fold on mine. It was not what I'd call easy to remove an like most tri-folds it takes up about 1/3 of the bed. I also found the latches at the rear difficult to use. I switched to a Truxedo low-pro roll up and like it a lot better. Not only does it take up almost no space when rolled up, it requires no tools and is super easy to remove if you want it completely off the truck. I've installed a Tyger and a Gator roll up tonneau on other trucks and the Truxedo is far and away the easiest to install and will be the easiest to remove the cover from the rails if I want to. Look around on Amazon and see if you can find one that was returned. I saved a few hundred dollars by buying mine that way.
    https://www.amazon.com/dp/B018YFTTMW
  6. Dec 22, 2022 at 5:17 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Also another truxedo fan. easy to roll up, no holes, light. Keeps eyes and hands out
  7. Dec 22, 2022 at 5:20 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    2nd Gen here, but another vote for Truxedo (LoPro).
    auskip07 likes this.
  8. Dec 22, 2022 at 5:29 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Regarding the Toyota tri-fold tonneau cover, it is heavy and unwieldy for one person to remove and install; it's doable in a pinch, but as others have mentioned, it is best to have two folks. Regarding the single bolt, I bought a 3/8 drive breaker bar and a 12mm socket from Amazon which I keep behind the rear seat so I can R&R the tonneau cover when necessary.
    Were it not that my Tacoma came with the cover, I would have sprung for a Lomax or Bakflip as they seem much easier to manage for one person than the Toyota cover. Please understand, I'm not dissing the Toyota cover, it is quite rugged and looks like it'll last the life of the truck, it is just bulky and heavy.
  9. Dec 23, 2022 at 6:22 AM
    atc250r
    Orange County, NY
    It must only be the factory hard covers that needed the bolt removed. I dudbt have to do that with my soft tri-fold.
  10. Dec 23, 2022 at 6:38 AM
    Horseshoez
    Dale
    Maryland
    Yeah, as far as I know, it is only the factory Tonneau cover which has the (external) bolt. I don't mind it though, I spent a couple of bucks on Amazon and have the wrench always in the truck so I can pull the bolt on an as needed basis.
  11. Dec 23, 2022 at 6:50 AM
    MJR
    MJR Well-Known Member
    Mickey
    Salado, TX & Santa Rosa Beach, FL
    ‘23 LIMITED 4wd NIGHTSHADE & ‘23 T4R TRD ORP
    Removed factory bed cover and installed UnderCover Elite. Added LOCKERDOWN console safe.
    just added this UnderCover Elite to new Tacoma this month.
    Went back with UnderCover because used it on 2014 for 10 years and 125k miles with 100+ taking off and putting on. NOT A DROP OF WATER.
    Very easy on/off with wife but did do once by myself just to see and it worked.
  12. Dec 23, 2022 at 7:01 AM
    MJR
    Mickey
