Bed Cubby Caps
Discussion in '3rd Gen Tacoma Parts Marketplace (2016+)' started by micwillia, May 18, 2017.
  1. May 18, 2017 at 6:39 AM
    micwillia
    micwillia [OP] Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    For those that have received their covers the installation guide has been attached to the bottom of this post
    **Order Form**
    Cubbies - $20
    Gaskets - +$2 per gasket type
    *Fits 2nd & 3rd gen cubbies (1st gen sadly weren't special enough to get them:pout:)
    I got sick of having moisture and road debris getting into the bed cubbies, so I designed some covers that'll work to stop that from happening. Introducing Cubby Covers: IMG_20170517_223614229.jpg
    These work to cover the slots on the top and bottom of the cubby, where the latches and clips go, while still allowing for full use of the OEM doors or aftermarket metal doors. The covers being sent out will be black like above but for prototyping I used white for my own set, which also helped for the photos.
    They are priced at $20 for a full set that'll fit either TRD or SR sizes (TRD= 1 LG + 1 SM & SR= 2 LG cubbies) and a set will also include hole plugs for the drains at the back of the cubby. I found a gasket that can be added onto the OEM doors to help seal out the water; which can be included for an additional $2. These prices included shipping, if you live in Canada if you could add ~$5 to cover additional shipping costs I'll gladly ship to you as well. To place an order use this Order Form (if you could send it as friends & family that would be helpful for me). The order form will ask you what size you need and has information for payment as well.
    I did testing to insure that the covers and gaskets would work:
    IMG_20170517_181645872.jpg IMG_20170517_182245670.jpg IMG_20170517_180306565.jpg IMG_20170517_180337029.jpg IMG_20170517_181008535.jpg
    Each cubby had a piece of paper inside to gauge how much water got in, and the results are that either option would prevent water from getting in. I sprayed the door and seals then from underneath. (I thought for sure that the LG OEM door was going to leak since I cut the gasket short, seen above, but to my surprise it was still bone dry)
    For the aftermarket locking metal doors the seal provided by the company did not seal out water so I found a better option that was used in this testing.IMG_20170517_181832991_HDR.jpg
    The original thread this started in is, https://www.tacomaworld.com/threads/trying-to-gauge-interest-on-selling-an-add-on-piece.490631/, if you want to see more information or the process.
  2. May 18, 2017 at 6:47 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Can these be installed with the cubby taken out, applied, and reinstalled, or does it require going under the truck to install?
    I would like to make sure the cubby is clean so the seal sticks properly.
    ChadsPride likes this.
  3. May 18, 2017 at 6:48 AM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Sign me up.
  4. May 18, 2017 at 6:49 AM
    Chief Taco
    Chief Taco Tacomasaurus Rex
    Nicholas
    Indianapolis, Indiana
    2016 TRD OR DCSB
    Mobtown Offroad IFS Aluminum Skidplate Low-Range Rear Diff Mod
    How do I order? Maybe I missed it but does the door gasket come with it and will that work with original plastic doors?
  5. May 18, 2017 at 6:51 AM
    micwillia
    Cental Masshole
    I'm putting together instructions to go with every set but, yes I would recommend cleaning the cubbies prior to installing. So they will have to be removed for cleaning and to apply the top covers but, the bottom covers will need to be applied while the cubbies are attached to the bed.
    ChadsPride and tomwil like this.
  6. May 18, 2017 at 6:52 AM
    micwillia
    Cental Masshole
    See above, Google form for placing the order, gasket for OEM doors are an additional $2
  7. May 18, 2017 at 6:59 AM
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    PP sent
  8. May 18, 2017 at 7:06 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    in
    Wallbright likes this.
  9. May 18, 2017 at 7:07 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Ordered SR and paid $22. Thanks!
  10. May 18, 2017 at 8:14 AM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    a cool sticker and a baseball card With clothes pin, sounds awesome ! wicked
    I'm in and $$$$ sent
  11. May 18, 2017 at 8:57 AM
    ZachUA
    ZachUA Well-Known Member
    Just filled out the form and sent payment.
  12. May 18, 2017 at 11:25 AM
    Chief Taco
    Nicholas
    2016 TRD OR DCSB
    dang I did read right over it too I am weaksauce.... ill get me one very soon!
  13. May 18, 2017 at 2:24 PM
    ProfessorX
    ProfessorX Well-Known Member
    Jimmy
    Menifee, Ca.
    2001 4DR TRD 4x4(sold) 2016 DC SB TRD OR 4x4
    Filled out form and paid! Thanks!!
  14. May 18, 2017 at 2:45 PM
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT
    Filled out the form and sent payment.
  15. May 18, 2017 at 3:02 PM
    Grand dude
    Dave
    lehigh valley, PA.
    Hay mike will we get a conformation or tracking # or anything
  16. May 18, 2017 at 4:26 PM
    MilkTeacoma
    MilkTeacoma Well-Known Member
    Payment sent!!!
    BTW, that form is legit. But have a suggestion...
    For question #2, I would rephrase the question and answers.
    What trim level do you own? *
    • SR model (has two large cubbies)
    • TRD model (has one large & one small cubby with inverter)
    Also recommend adding your Paypal Link right above the submit button. I couldn't find it at first. LOL
    TRDSport10, HawaiianSON and Blais03 like this.
  17. May 18, 2017 at 4:31 PM
    Hojae84
    Hojae84 Well-Known Member
    Bedford NY
    2008 dcsb 4x4 sr5
    Curtis home pro, front rear cameras, side blind spot cameras and more
    Ima gonna get these. Just to confirm- these also stop water coming into the cubby from under the truck correct?
  18. May 18, 2017 at 6:10 PM
    ProfessorX
    Jimmy
    Menifee, Ca.
    Yes they do :)
  19. May 18, 2017 at 7:04 PM
    Lalo73
    Lalo73 Well-Known Member
    Everardo
    El Centro
    2017 RED TRD PRO
    TINT, BFG TIRES 265 75 R16 , SPEAKERS AMP, BIKE RACK, BED MAT
    Ok i will have a set
  20. May 18, 2017 at 7:07 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton Mass
    '08 Reg. Cab 4WD 5-speed
    Too much to list
    Yeah I'm in!
