Bed D-Ring Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nettereo16, Aug 27, 2023.
  1. Aug 27, 2023 at 5:58 PM
    nettereo16
    nettereo16 [OP] Active Member
    Durham, NC
    06 TRD Sport AC
    One of my bed D-Rings was rusted really bad, so I took the angle grinder to it to cut through the bolt figuring I could knock the bolt out and replace the ring and bolt.
    The bolt isn't coming out... is it threaded or something? Does someone has a schematic of these bolts on the frame?
    Thanks!
  2. Aug 27, 2023 at 6:54 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    The bolt that holds the d-ring also holds the bed to the chassis. Definitely threaded, and even when the part you ground off is still attached they can sometimes be quite stubborn to get out. Good luck...
