bed d-rings on a 2011 tacoma
Discussion in 'New Members' started by gb11tacoma, Jul 27, 2011.
  1. Jul 27, 2011 at 2:04 PM
    gb11tacoma
    gb11tacoma [OP] Member
    george
    somerville,mass
    tacoma4X4
    should i put a few near the cab? the ones near the tailgate are useless...please give me some info because the dealer doesnt want me to drill through a composite bed. has anyone else added these near the cab???? thanks george.
  2. Jul 27, 2011 at 2:07 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
  3. Jul 27, 2011 at 2:08 PM
    gb11tacoma
    george
    somerville,mass
    tacoma4X4
    ant help will be useful.
  4. Jul 27, 2011 at 2:11 PM
    G1TRD0N3
    G1TRD0N3 Member
    Kyle
    Ottawa, Ontario, Canada
    08 TRD Off-Road, DB Cab, Short Box
    I went to a junkyard and got two off a busted 05. Replaced the washers on the two bolts near the cab with them. Worked great, no drilling/grinding required. That or see previous post on using search :p
  5. Jul 27, 2011 at 7:02 PM
    hutchg
    hutchg Member
    I picked up a couple of D-rings to put under the front two bed bolts. When I unscrew the bed bolts they come up an inch or so and then stop. I didn't want to force them too much so I just screwed them back down.
    Anyone else have this issue?
  6. Jul 27, 2011 at 7:25 PM
    BigRed4x4
    BigRed4x4 Member
    Texas
    DCLB SR5 4x4
    You post was like Deja Vu. I was wondering the same thing, but I went ahead with it. I don't haul heavy loads, so I think it will be fine (kayaks mostly). I mounted mine close to the front corners. I set the bracket on the bottom sideways, so it extends to the side of the truck bed. I figure some of the load will pull against the vertical sides of the bed for more strength. I haven't tried them out yet.
  7. Jun 21, 2012 at 5:54 PM
    HXC
    HXC Well-Known Member
    Cory
    Houston, Texas
    2011 white Dbl cab 4x4 6spd man.
    I got a pair to put on my 2011 d-cab, but my gas tank is in the way. I was gonna use the existing drain holes by drilling them out. I can get the passenger but not driver side. Anyone else have this issue?
  8. Jun 21, 2012 at 6:24 PM
    M202Flash
    M202Flash Well-Known Member
    California
    '11 TRD DCSB
    Diff breather mod/JP Metal Fab Tie Downs/Plasti-dip front valance/Famous Fabrication Sliders/Illumination Supply LED Spotlights w/ Relentless Hood Hinge Light Mounts/Bora 1" Spacers/Westin Brush Guard/BajaRack/Goodyear Duratracs 265-75-16
    I use these constantly. The installation was easy in these two locations as the backside of the bed was accessible for the back plates.
