Bed denting cab?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adhumston, Apr 24, 2021.
  1. Apr 24, 2021 at 9:29 PM
    TacoMatic4x4
    TacoMatic4x4 Well-Known Member
    87' Suzuki Samurai, 98' Toyota Avalon, 2018 Cement TRD Offroad DCLB 4x4
    Is it dented on both side or just the right side? Do you have a RTT that would flex the bed?
    4×4×4 likes this.
  2. Apr 24, 2021 at 9:36 PM
    adhumston
    adhumston [OP] Well-Known Member
    Just the one side. Nothing on bed, other than the Retrax
  3. Apr 24, 2021 at 9:37 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I was moab beginning of April went on trails 5 days never experienced it I'm a short box not sure if that makes a difference more rigid?
  4. Apr 24, 2021 at 9:40 PM
    adhumston
    Short box too. I think it may have been from the St George/Hurricane area.
  5. Apr 24, 2021 at 9:40 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Op is a short bed as well. I think.
    shakerhood likes this.
  6. Apr 24, 2021 at 9:51 PM
    4×4×4
    4×4×4 Well-Known Member
    Well thats certainly strange, I'd check bed bolts, otherwise.... well I've never heard of anything like this before
    Was there a specific event where you heard or felt something weird that would have done this?
  7. Apr 24, 2021 at 10:04 PM
    adhumston
    Nothing that stands out. Obviously drug the rear quite a few times, but not unexpected
  8. Apr 24, 2021 at 10:52 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I had the same issue but with no damages yet with my brand new truck, see my post #114- and all the others on this thread below, your bed is out of alignment to the frame and the cab may be as well. It was a warranty fix, hope yours is too.
    https://www.tacomaworld.com/threads/bed-alignment-issues.436090/page-6#post-15955444
    PzTank, BudFriendguy and 4×4×4 like this.
  9. Apr 25, 2021 at 4:38 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Is it just me or does the bed look super close to the cab of the truck . Like it was installed incorrectly.
    PzTank and Chew like this.
  10. Apr 25, 2021 at 4:47 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    The ratchet strap should fix that issue....
    shakerhood[QUOTED] likes this.
  11. Apr 25, 2021 at 4:54 AM
    Pat3002t
    Pat3002t Well-Known Member
    3rd gen SR 2.7 5MT
    Wonder if enough force applied while dragging the tow hitch could do that. If it’s even possible.
  12. Apr 25, 2021 at 5:20 AM
    TomTD
    TomTD Well-Known Member
    2018 TRD Sport
    No way that the bed made those dents. How wide are your tires? Looks like they could have kicked something up.
    4×4×4 likes this.
  13. Apr 25, 2021 at 5:35 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    No it's not normal .
    Chew likes this.
  14. Apr 25, 2021 at 5:38 AM
    Bleep100
    17 Sport
    Just one side then someone left something lay there and it fell in the gap .
    TacoMatic4x4 and 4×4×4 like this.
  15. Apr 25, 2021 at 6:27 AM
    #35
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Did you jump it?
    At slow speeds like trail speeds, there is no way you get enough flex to do that.
    However, at high speeds like jumping the damn thing, it changes because now you have more dynamic forces and it could flex enough to do that.
    Send it.
    Lawfarin, tcjacado and Chew like this.
  16. Apr 25, 2021 at 7:32 AM
    #36
    RatDaddy
    Roy
    None
    Unfortunately, flex and bed to cab damage in trucks is common. If you think about how a truck is built, you have a flat ladder frame connecting bed to cab.
    Very similar to how your spine connects your hips to your rib cage. The only thing stiffening the center is your core muscles. Same with trucks. There is only so much you can do to stiffen a frame. By contrast an SUV is a solid piece body connecting to the frame which makes the entire unit considerably stiffer.
    The only thing you can to prevent this is stiffen everything up as much as you can. Bed stiffeners are cheap and help. Frame bolted skids add a lot of rigidity to a frame. I am adding RCI skids and armor to my truck more for the stiffening than protection.
    shotgunbilly420 likes this.
  17. Apr 25, 2021 at 7:34 AM
    #37
    adhumston
    They're from the bed. Easier to tell in person.
    TomTD[QUOTED] likes this.
  18. Apr 25, 2021 at 7:36 AM
    #38
    adhumston
    That's kind of what i assumed. I do have skids. Unfortunately my bed stiffenera and sliders haven't arrived yet
    RatDaddy[QUOTED] likes this.
  19. Apr 25, 2021 at 7:37 AM
    #39
    adhumston
    No jumps.
    hiPSI[QUOTED] likes this.
  20. Apr 25, 2021 at 7:40 AM
    #40
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Are you even really driving it if you're not gapping it like Boss Hogg is after you?
    hiPSI and adhumston[QUOTED][OP] like this.
