Bed dimensions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Firefly765, Aug 10, 2023.
  1. Aug 10, 2023 at 8:53 AM
    Firefly765
    Firefly765 [OP] New Member
    Does anyone know if the truck bed dimensions on the 2022 double cab versus the 2023 double cab are exactly the same? I am looking to buy a tonneau cover and it says it fits the 2022 model but not the 2023 model. I am wondering if maybe just their website information is not updated to accommodate the 2023 Tacoma??
  2. Aug 10, 2023 at 8:55 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Double cab comes in 5ft or 6ft bed.
    Pick the length u need and go
    Chew and Firefly765[OP] like this.
  3. Aug 10, 2023 at 8:57 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    No bed changes at all between those two model years. The vendor just hasn't updated their compatibility for this year.
    RedWings44, Chew and Firefly765[OP] like this.
  4. Aug 10, 2023 at 9:49 AM
    Firefly765
    That’s what I thought……..thanks!
  5. Aug 10, 2023 at 12:54 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    speaking of a 5' bed - if I get a 60" Hi-Lift jack (which is actually 61.75") and unbolt the base and the winch connector (I think that is what is on top) will it fit on my side mollie panel in the bed ? I can store the base and the winch connector with the recovery stuff.
