Bed Divider Options to use W/ Undercover SE Cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fireman610, Mar 15, 2013.
  1. Mar 15, 2013 at 4:22 PM
    Fireman610
    Fireman610 [OP] Well-Known Member
    Evansville IN
    07 TRD DoubleCab 4x4
    I Have an 07 and recently got a killer deal on a Undercover SE painted Cover I now need Ideas on what Options I have as far a a divider or organizer. I have too much junk rolling around Turnout gear Med Bag Helmets Rope Bag Etc Etc. I had heard somewhere that the Toyota cargo dividers wont work w the Undercover SE very well? Is this true?? I basically need something to go from Bedside to Bedside (just behind wheel wells) and bed height. thought about a cargo bar and sheet of Lexan but F that at 63.00 for a 16 3/4 by 59 sheet thats cut.
    Help Any Ideas??
  2. Mar 15, 2013 at 4:26 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    12 TRD Sport AC 4x4
    I used two cargo bars and a cheap tailgate net
  3. Mar 15, 2013 at 4:38 PM
    cotaco05
    cotaco05 Well-Known Member
    Jeff
    CO
    '17 Double Cab Off Road
    You may be able to use the Toyota cargo divider. The pieces on the ends that fit into the deckrail management system can be removed from the divider itself and re installed with the tightening knobs on the bottom. I believe this will give you enough clearance for the Undercover to close without interfering with the divider. I had a similar setup on an '08 Tundra with the deckrail management system that I owned and this worked for me on that truck.
    Turnout bag is a PITA to haul. Stay safe brother.
  4. Mar 15, 2013 at 4:39 PM
    Fireman610
    Evansville IN
    Cargo net wont hold up w the heavy stuff that will be tossed in there. I'd want more of a Webbing/seatbelt material style cargo net if I did that
  5. Mar 15, 2013 at 7:13 PM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
  6. Mar 15, 2013 at 8:45 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    When I had my hard shell Undercover Tonneau cover, I just bought a crappy cargo bar. It worked in holding everything in it's place and it never effected the closing or the opening of the tonneau cover.
  7. Nov 24, 2014 at 7:37 PM
    KB Voodoo
    KB Voodoo Well-Known Member Vendor
    Chad
    Glenwood, NY
    www.kbvoodoo.com
