Bed Dividers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PilotguyPA28, Aug 20, 2020.
  1. Aug 20, 2020 at 9:25 AM
    PilotguyPA28
    PilotguyPA28 [OP] Well-Known Member
    Trip
    2020 Metallic Gray Limited
    If I add a rubber mat will a bed divider still fit? I would think they leave some space at the bottom of the divider. Also, what brand will work on the OEM rails? If I add a Tonneau will I lose use of the OEM rails?
  2. Aug 20, 2020 at 4:51 PM
    mmcarbo
    mmcarbo Well-Known Member
    Massachusetts
    I ponied up for the Toyota bed divider. The OEM bed mat fits fine under it. Install the divider knobs upside down so they don’t interfere with an over the rail roll up cover.
    Boghog1 and PilotguyPA28[OP] like this.
  3. Aug 20, 2020 at 5:09 PM
    PilotguyPA28
    Trip
    Thanks for the tip.
  4. Aug 20, 2020 at 5:11 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  5. Aug 20, 2020 at 5:32 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  6. Aug 20, 2020 at 5:42 PM
    Grossomotto
    2017 4WDV6LB6MT
  7. Aug 20, 2020 at 5:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  8. Aug 20, 2020 at 5:47 PM
    Grossomotto
    2017 4WDV6LB6MT
  9. Aug 20, 2020 at 5:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's like morning in a cup.
    :pccoffee:
    Grossomotto[QUOTED] likes this.
  10. Aug 20, 2020 at 6:06 PM
    PilotguyPA28
    Trip
  11. Aug 20, 2020 at 6:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's a rule that you have to put it on the back of your KLR. :rofl:
    Boghog1[QUOTED] and Grossomotto like this.
  12. Aug 20, 2020 at 6:35 PM
    Grossomotto
    2017 4WDV6LB6MT
    It's just a regular 6 gallon rectangle milk crate. The square ones are 4 gallon, not sure on the dimensions. I've found them cheap on craigslist, some people will buy hundreds when a dairy goes out of business and sell them for cheap like $2-3 each.
    They're actually great for off roading because you can put gallons of water in there without them flying around.
  13. Aug 20, 2020 at 7:38 PM
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    Lots of boxes or mesh or bars.
    I use a crate for misc and a load bar to hold “whatever” at rear bed for access.
    Though the Toyota divider is expensive, that’s the only real device to hold items safely
    Gas cans
    Propane
    Etc
    I wouldn’t trust my load bar slipping up and releasing.
    Be nice to come up w an easy fix and not hundreds of $$
    PilotguyPA28[OP] likes this.
  14. Aug 20, 2020 at 8:00 PM
    a400ryan
    2015 SR5 DCLB
    Moulded slates (as in other brands) in bed sides to hold a 2x6 would do the trick
    tonered likes this.
