Bed doesn't line up with cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HARDSHELLTACO, Apr 14, 2010.
  1. Apr 14, 2010 at 9:15 PM
    HARDSHELLTACO
    HARDSHELLTACO [OP] HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I think I have seen this on here somewhere but I couldn't find it. I just noticed this last weekend on my pass side the bed is out of line with the cab. Anyone else have this? Makes me wonder if my truck has been hit at some point. No visible body or frame damage. Is there some sort of adjustment that can be made.
  2. Apr 14, 2010 at 9:16 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmmm? I have never heard of anything like that.:rolleyes: Now I am going to have to take a look when I get a chance. Thanks for the heads up.:cool:
  3. Apr 14, 2010 at 9:22 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    my bed is the same way in relation to the cab. my frame was bent from the factory. i've been going back and forth with my dealer for a while now trying to get toyota to pay for the frame pull i need.
    Note: my dealer is great. it's not their fault, they are just my contact to actual toyota.
    i'd get the rear alignment checked...there is no adjustment to the rear of our trucks, so if you find the alignment is off on the rear, you more than likely have a bend somewhere in your frame. that's how i found mine...first time i got my truck aligned, the the alignment guy (not at toyota) said that it should drive fine, but just fyi, my rear somehow is out.
    hope this helps. i also how you don't have a bent frame (it's unlikely you do).
  4. Apr 14, 2010 at 9:35 PM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    The meteor probably knocked yours out of line.
  5. Apr 16, 2010 at 2:55 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    oh shit i thought i was the only one. the passenger side of mine sits closer to the cab compared to the drivers side:confused:
  6. Jan 1, 2011 at 5:03 PM
    Got Tacoma
    Got Tacoma Well-Known Member
    Gila
    Arizona
    2010 Dbl. Cab Sb 4 x 4 Trd
    Undercover Tonneau, Roof Rack, ABR Bumper, Warn 9.5xp, OME 886, Dakar leaf springs, Bilstein 5100 Struts and shocks
    I have a 2010 Double Cab. All the double cabs from the factory are misaligned. Put you fingers in between the cab and the bed on driver and passenger side and move your hand up and down in the space. The drivers side is tighter than the passenger side by almost double. Viewing from the rear the bed is misaligned sideways. The bed aligned more to the passenger side. Or the cab may be misaligned. I do not have a bent frame. A few days after my purchase I went to a couple of Toyota dealers and checked literally over 50 double cabs they were all misaligned but not to the same degree. Some were tighter and some looser but all were misaligned. Is this a defect in design or manufacturer? If this why from what I hear Toyota moved it's Tacoma assembly to Texas? This problem does not exist on the regular cab or the access cab only the double cab.
  7. Jan 1, 2011 at 5:44 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    2011 access cab, box misaligned by about half a inch.
    Went to a toyota dealer and checked another access cab, which was also misaligned.
    Saw the misalignement after being lightly hit on my tow hitch, my frame seems to be ok (visually). I don't think that the hit actually created the misalignement.
  8. Jan 6, 2011 at 12:02 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Mine looks slightly misaligned too. I've noticed though when going over small bumps at highway speeds the box shakes and moves in a very weird way (can't really explain it in words) like as if the bolts holding the box to the frame is loose and might just suddenly fall off of the frame. I know that sounds really stupid but all of the other trucks that I have driven have never done that. :confused:
    BTW, mine was built in California
  9. Jan 6, 2011 at 6:16 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    "Suddenly fall off the frame" I would be checking those bed bolts if its moving that much. This thread has tweeked my intrest so I'll be checking the bed to cab gap tonight.
  10. Jan 6, 2011 at 8:56 AM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    do you have TSB springs installed..just asking because after i had the springs installed my rear was was out of whack on the alignment machine.. turns out the holes for the spring where drilled off center.
  11. Jan 6, 2011 at 9:04 AM
    Patrobs
    Patrobs Well-Known Member
    Patrick
    New Hampshire
    2012 Dbl Cab Short bed TRD Offroad
    I thought I was nuts when I noticed mine. I didnt notice it until I got tires that stuck out farther then I looked at the bed and realized one side was flush and the other is off by atleast 1/2- 3/4 of an inch!
  12. Jan 6, 2011 at 9:30 AM
    tdcoly
    tdcoly Well-Known Member
    The bed is mounted solidly to the frame. The cab, however, is mounted on cushioned mounts. What you see is the cab moving. Perfectly normal.
  13. Jan 6, 2011 at 9:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Just loosen the bed bolts and realign it.
  14. Jan 6, 2011 at 9:35 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    ^ding...there are bolt heads in the bed of the truck...loosen up a bit, move til you are happy, tighten back down.
  15. Jan 6, 2011 at 9:38 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    is it a possibility the cab is whats misaligned? after all the bed is mounted solid to the frame and the cab is rubber mounted...
  16. Jan 6, 2011 at 9:39 AM
    Yoytoda
    Roland
    completely stock
    damn, im too slow
  17. Jan 6, 2011 at 11:51 AM
    MTSUMATT
    MTSUMATT New Member
    Middle Tennessee
    2011 Double Cab TRD OR
    Trifecta Bed Cover
    When I bought my truck the bed was actually lower on the right side. This is different from your problem, but I took it back to the dealer and we measured it together and they agreed. The next day they fixed it by removing the bed and inserting appropriate spacers between it and the frame.
    Just thought I would tell you my experiece with a similar issue.
  18. Jan 6, 2011 at 2:47 PM
    supralight
    Dan
    Earth
    thx for the advice!
  19. Jan 6, 2011 at 2:48 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    my bed sits a lil higher in the front left side compared to the right, not sure why lol
  20. Jan 30, 2011 at 4:48 PM
    Poffdaddy
    Poffdaddy Member
    Carlsbad, CA
    09 Tacoma 4x4 TRD Sport Long bed
    TSB, AAL, TRD Baja suspension kit, SnugTop Cab-hi shell, front tint
    Fixed mine today, loosened the 6 bolts in the bed and slid bed over to correct. Came brand new 3/4" clearance behind cab on driver's side and 1 1/2" passenger side and pushed a little right. Now it is just over 1" on both sides and equal side to side. It did make the bumper clearance slightly unequal on the sides but it is close enough for me.
