Bed extended install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jstrength, Oct 6, 2018.
  1. Oct 6, 2018 at 11:47 AM
    jstrength
    jstrength [OP] Member
    2018 Cement gray Tacoma TRD Sport
    Hey guys. Bout to install an AMP HD bed extender. I have the Toyota rubber bed mat as well. Do I need to remove the mat when fitting and installing the extended or just leave in? TIA
  2. Oct 6, 2018 at 11:54 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Leave the mat in place just follow the instructions. Location is key so measure 2x as they say.
  3. Oct 6, 2018 at 12:15 PM
    jstrength
    When you say measure 2x should I still use the template they give and then what? Sorry just a little nervous about drilling holes in the new Taco.
    Thanks
  4. Oct 6, 2018 at 2:43 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Just double check before you start drilling holes. In my experience, I taped the templates about 1/4-1/2 inch high because the rubber Legs on the extender don't fall between the raised portions of the bed. My bed extender is a little bit older but still made by AMP installs the same way. But just double check this part for yours And yes,I would remove the bed mat.
    Tape the templates and put the bed extender inside and hold it so The pivot points line up with the center of the bracket picture. You want the extender to be nice and level when in the open and closed position with the tailgate opened or closed. And make sure you have the extender as close to the edge of the tailgate when opened. Then make sure you can still close the tailgate with the extender put away.
