bed extender as bed divider?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lucaslucas, May 13, 2016.
  1. May 13, 2016 at 10:56 AM
    daway
    daway Well-Known Member
    Seattle, WA
    2016 TRD Off-Road DCSB
    Prinsu cabrack, Bestop Canopy, bed extender, plastidipped black grill
    I forgot to mention I have a Bestop soft canopy. Even without a canopy, my pup wouldn't jump out. If you had a dog crate, you most certainly would not be able to fit it between the tailgate and the bed extender.
  2. May 13, 2016 at 11:03 AM
    lucaslucas
    lucaslucas [OP] Active Member
    my dog will def jump out :(
  3. May 14, 2016 at 4:26 AM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  4. May 15, 2016 at 5:24 AM
    froejoe
    froejoe Well-Known Member
    Rochester NY
    2016 TRD Sport 4x4 Access Cab
    As an FYI, I learned in another thread that the AMP product uses sheet metal screws to mount the side brackets whereas the OEM uses bolts and nuts. If this matters to you, here are the 2 OEM part numbers, one for the older style and one for new style bed extenders. Also, attached is the OEM installation guide so you can compare it with AMP installation.
  5. May 16, 2016 at 6:47 AM
    froejoe
    Rochester NY
    Just wondering...
    When folded back into the bed without any cargo, does the OEM bed extender vibrate/jump up & down/make audible noise?
  6. May 16, 2016 at 7:19 AM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    Mine makes no noise whatsoever.
  7. May 16, 2016 at 7:34 AM
    froejoe
    Rochester NY
    Assuming you have the "newer" D-shaped extender rather than the "older" U-shaped extender, do you feel like you're giving up any appreciable storage space?
  8. May 16, 2016 at 7:38 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    No noise or vibration at all.
  9. May 16, 2016 at 7:39 AM
    Boerseun
    Ferdie
    Sarasota, Florida
    I use my bed extender as a bed divider probably 90% of the time and as an extender only 10% of the time. Works great in both applications though.
  10. May 16, 2016 at 7:43 AM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    I do have the d shaped one. It works well for everything I've needed.
    it's the best bang per buck mod that I've done.
  11. May 17, 2016 at 6:28 AM
    lucaslucas
    any one has both of them? the extender and the divider? like one better than the other?
  12. May 17, 2016 at 6:41 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^The advantages/disadvantages seem pretty clear. The bed divider can slide along the bed rails so you hold stuff close to the headboard. It's heavier-duty but also heavy at ~ 100 lb. The knobs interfere with many tonneau and cap designs.
  13. May 17, 2016 at 6:43 AM
    KenLyns
    Belly of the Beast
    Me? I use a Honda Pilot trunk organizer strapped to the O-rings. :D
  14. May 17, 2016 at 8:19 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    I also use mine as a be divider. it has plenty of space for most day to day things, ~$200 groceries, most ice chests, etc. Yes, i have the factory tonneau cover and as you can see, it does fit with both. the only complaint, if you want to call it that, (really just a side note), in order to flip the bed extender out, you need to open the cover completely, rather than just once
  15. May 17, 2016 at 8:21 AM
    #35
    mbarbay
    Baton Rouge, LA
    the extender has rubber bumpers to absorb bumps and reduce noises. I have never heard mine, while driving
  16. May 17, 2016 at 10:02 AM
    #36
    froejoe
    Rochester NY
    Cool :) Thanks, All, for your input. I ordered one through my local dealer today. Surprisingly, they price-matched online sales quotes.
  17. May 17, 2016 at 10:34 AM
    #37
    lucaslucas
    how much u payed?
  18. May 17, 2016 at 12:38 PM
    #38
    froejoe
    Rochester NY
    $200 + change.
  19. May 17, 2016 at 6:59 PM
    #39
    jacktheveganpilot
    jacktheveganpilot New Member
    2016 White Tacoma TRD Sport
    Where did you buy this from? Would like to order one. Thanks
  20. May 18, 2016 at 6:30 AM
    #40
    froejoe
    Rochester NY
    Just google the part number, which I posted earlier in this thread. You'll find many sources for this item. I simply printed out one of the online price quotes and showed it to my local dealer. They price-matched it, and I saved on shipping costs. Your mileage may vary. :)
