Bed Extender Mounting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by douggytundra, Nov 21, 2010.
  1. Nov 21, 2010 at 3:31 PM
    douggytundra
    douggytundra [OP] Well-Known Member
    orlando
    09 D-CAB 4x4 White Sport Taco
    I am really not sure how the factory bed extender mounts and would like to see some pics of the mounts. I will be buying one and really would like to see before I purchase. Thanks Guys
  2. Nov 21, 2010 at 4:34 PM
    Chronism
    Chronism Well-Known Member
    Michael
    Richmond, Virginia
    2011 Tacoma TRD OR/DC
    Too dark outside to take a pic, will tomorrow if nobody else beats me to it. Basically you drill three holes into the metal part of the bed wall at the tail lights, pop off the tail lights, and install with a screw/nut behind the tail lights for each side.
  3. Nov 21, 2010 at 4:36 PM
    douggytundra
    orlando
    Thanks. The pics will be great.
  4. Nov 23, 2010 at 3:14 PM
    Chronism
    Michael
    Richmond, Virginia
    Sorry for the delay, didn't have a chance to take a pic yesterday before it got dark again. Hopes this helps...
  5. Nov 23, 2010 at 3:27 PM
    douggytundra
    orlando
    Thank you very much. No doubt you are my savior. Thanks
  6. Nov 23, 2010 at 3:30 PM
    Chronism
    Michael
    Richmond, Virginia
    No problem. Install is simple, just align them up with the supplied template, remove a couple of bolts (seen in the picture) to remove the tail lights which pop right off after the bolts are removed, drill your holes, and run the bolts thru and install nuts behind tail lights.
