Bed extender questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CountofQ, May 28, 2018.
  1. May 28, 2018 at 5:15 PM
    CountofQ
    CountofQ [OP] Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    How does it / how easy is it to install one?
    How easy does it "flip" from not in use to in use?
    What are the actual dimensions from inside corners to the tailgate (when inside the bed/not in use)? How far between the two inside corners?
    How much weight can the rails support?
    Does it block the outlet in the TRD OR model?
    Thanks.
  2. May 28, 2018 at 5:26 PM
    deneb64
    deneb64 Member
    2016 MGM DCSB Limited
    Bed Extender, front bed rail, weather tech mats
    They are really easy to install. You just need to pop out the taillights and using supplied templated drill the holes. Cover the holes with anti-rust.
    The bed extender are very simple to take in and put back. Just lift, the extender will come out. To set it back, is the same.
    When not in use, you flip it inside, the dimension is around 24 inches to the tailgate, and the width is around the same as the width of bed minus 3-4 in each side.
    I did not measured mine just eyeballed . Mine is the original Toyota part.
    CountofQ[OP] likes this.
  3. May 28, 2018 at 5:36 PM
    CountofQ
    Duluth, MN
    Thanks.
    The distance between the "short" "inside" corners? You know... the 45*s. Or I guess, the length of the rails that run parallel to the tailgate.
    Am trying to determine if one of my smaller gang/tool boxes would slide easily in (while not in use), when transporting from jobsite to jobsite.
    Also, wondering how much weight they might be able to take. Say if I wanted to transport some electrical conduit (10' lengths).
  4. May 28, 2018 at 5:42 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have one and use it quite a bit. I wouldn't rest much over 50 lbs on it though.
    CountofQ[QUOTED][OP] likes this.
  5. May 28, 2018 at 6:58 PM
    deneb64
    deneb64 Member
    the bed extender forms a "c". The end of the c" is 22 inch, the middle is 33 inch and opening is 47 inch
  6. May 29, 2018 at 3:35 AM
    CountofQ
    Duluth, MN
    Thanks all!!
  7. May 29, 2018 at 7:01 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    You do not need to remove tail lights. I installed my own extender.
  8. May 31, 2018 at 3:39 AM
    Soccer Mom
    Soccer Mom Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    Can anyone please post pics of how the bed extender is mounted and stowed with the tailgate closed when not in use?
  9. May 31, 2018 at 4:11 AM
    gtdad66
    gtdad66 Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    Mine is a Top Line Bed Extender, universal fit. Only takes up 4” of space when not in use am[nd can be removed in just seconds.
    cafereef and techgeekwill like this.
  10. May 31, 2018 at 10:51 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    I really like this, anyway I could get you to measure how far it sits from the bed sides when the tailgate is closed? I have bed stiffeners and want to see if it would fit inside and clear then when closed
    Thanks
  11. May 31, 2018 at 12:40 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    They are adjustable, bed stiffeners won’t be a problem.
  12. May 31, 2018 at 1:19 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    They are really easy to take out if you don’t want it in the bed or if you need to load the bed. Just extend it out 45 degrees above the tailgate and lift up. Also works great under a tonneau cover.
  13. Sep 5, 2021 at 10:17 AM
    woody2454
    woody2454 New Member
    21 tacoma
    I can't find them. Where can I get one. Yhanks!
  14. Sep 5, 2021 at 10:22 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Factory or like the one above? The factory one is also a 3rd party company that Toyota uses.
