Bed extender suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017sport, Jun 10, 2017.
  1. Apr 15, 2019 at 9:40 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    No. It has to be at 45% in order to remove or install.
    It's really easy to remove and install.
  2. Apr 16, 2019 at 3:12 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Honestly, I've never tried removing it from an upright position, but I have removed it facing the bed and facing the tailgate. I've released it on some pretty funky angles when only one of the tabs was in the bracket slot.
    I hope that helps.
  3. Apr 16, 2019 at 11:23 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Just want to make sure we are talking about this style below:
  4. Apr 16, 2019 at 8:11 PM
    Herniator
    Edmonton
    This is how it looks on my truck.
    specter208 likes this.
  5. Apr 16, 2019 at 9:03 PM
    itsnotatoy
    itsnotatoy Well-Known Member
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
  6. Apr 17, 2019 at 3:23 AM
    House Forsaken
    Paul
    Yup, those are them!
    specter208[QUOTED] likes this.
  7. Apr 17, 2019 at 3:50 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I have these ones. If you get them from the dealership they come with nuts and bolts instead of screws, and the hardware is powder coated black.
  8. Apr 17, 2019 at 5:30 AM
    DOSS
    DOSS Well-Known Member
    Scott
    Utah
    2016 Black Tacoma TRD Sport DBCB
    If you were in Utah I would give you mine.. its the AMP that is more square.. can't use it with my Caliraised bed stiffener things nor with my shell.. :)
  9. Apr 17, 2019 at 10:46 AM
    specter208
    California
    Awesome. I'm interested in upgrading to better mounts. I currently have the old style which are pictured below. The bed extender needs to be 90° to remove or install. With tall and bulky items it becomes impossible to remove and replace the bed extender which makes it useless sometimes.
  10. Apr 17, 2019 at 4:49 PM
    TX Bat
    TX Bat Enabler
    Keith
    North Texas
    2019 TRD Pro BLACK
    This makes me wonder.
    I still have the bed extender from my '01 Taco. I forgot to put it in when I sold it. I'm going to do some measuring and see if the old one will fit in my new Taco. All I would need are some brackets.
  11. Apr 18, 2019 at 10:08 AM
    specter208
    California
    There is a good chance that it will be compatible. The designs I've seen from AMP use sliding tubes that Are adjustable during assembly. I currently have a bed extender from a Nissan Frontier installed in the Tacoma. I only needed to slide the tubes inward to fit the narrower tailgate of the Tacoma.
  12. Apr 18, 2019 at 10:21 AM
    StevoNB
    NB, Canada
    I agree. I bought a used one that I disassembled and painted. I wouldn’t be surprised if it was compatible with a full size truck because the center tubes were so long.
  13. Apr 19, 2019 at 4:19 AM
    yoshitanoshi
    yoshitanoshi Well-Known Member
  14. Apr 19, 2019 at 2:22 PM
    Gmetaco
    Gmetaco Well-Known Member
    Greg
    2017 OR
    I have the OEM one and wish I had a different more square one. The rounded corners eat up space and when it's disconnected but still in the bed it teeters back and forth making noise as you drive
  15. Apr 19, 2019 at 2:30 PM
    #35
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Yeah the cut off/rounded corners really do limit the utility of the OEM one more than I would have expected. There is no conflict with the wheel wells so that it could have easily been squared off instead, not sure why they did that. Wish I had gotten an aftermarket one that was square or even just skipped it all together. The bed mat is surprisingly rubbery enough that things don't really slide around in there anyways.
  16. Apr 19, 2019 at 4:15 PM
    #36
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    For the quick release?
    I have the quick release (not the factory hardware) and never tilt mine to release it.
  17. Apr 19, 2019 at 4:55 PM
    #37
    StevoNB
    NB, Canada
    I read that they rounded the corners off because the squared off version can restrict people’s view of the tail lights from certain angles.
  18. Apr 19, 2019 at 6:43 PM
    #38
    deusxanime
    MN
    Yeah I think someone mentioned that earlier. It really cuts down on the utility more than I thought it would though. I end up just leaving it out most of the time at this point.
  19. Apr 19, 2019 at 8:17 PM
    #39
    Gmetaco
    Greg
    2017 OR
    I would consider switching mine out if I didn't have to drill more holes. Does anyone know if the OEM brackets work with a aftermarket extender.
  20. Apr 20, 2019 at 7:47 AM
    #40
    TX Bat
    TX Bat Enabler
    Keith
    North Texas
    2019 TRD Pro BLACK
    Did a little test fit and the extender from my '01 will fit. Those center bars do adjust too.
    Now I just need to find some brackets.
    Herniator, AxisCab and Modesto Tacoma like this.
