Bed Light Wiring Advice? (SOLVED)
Discussion in '3rd Gen. Tacomas (2016+)' started by mrkabc, Dec 25, 2017.
  1. Dec 25, 2017 at 6:54 PM
    mrkabc
    mrkabc [OP] Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Hi everyone and Merry Christmas!
    I installed my "factory" bed lights and I'm running into a problem - they won't light up! I ran out of daylight so diagnostics will have to wait until next weekend, but here's what I'm finding.
    I wired the negative side to this ground:
    It's a screw attached to the cluster plug recommended by the instruction manual - which read in step ii on page 7: "...Attach a YELLOW 12-10 AWG T-Tap to the factory ground point (White wire with BLACK trace) on kick panel wall..."
    LOL when you take a look at the pic, you can clearly see that they are ALL white wires with black traces, so I just tied in to the screw above since I don't like T-Taps.
    I have run the hot wire to the green wire coming from the cab light switch:
    Setting the switch to "On" lights up the cab bed lights, but the green wire doesn't register 12v on my VOM even though the factory cab bed lights are on.
    QUESTION 1: Is this the correct wire? The searches I have done indicate this is the correct wire to tap into for 12v switched bed lights, but since I'm not reading voltage (and the factory cab lights are lit, eliminating the blown fuse idea) make me wonder if I am barking up the wrong tree. BTW, my VOM was connected directly to the battery (-) terminal on the negative side when probing this green wire. I read another thread where a poster had similar troubles trying to find the correct "green" wire and burned off the insulation on a lot of them with no success.
    As a test, I ran the hot wire directly to the battery (+) terminal, my new lights are dead. I'm going to check the wires at the junction in the spare tire well first, then work my way backward, but before I do, here's...
    QUESTION 2: Is this the correct ground? I saw a reference in another search that lights may require their own separate ground? The instruction manual is crap and not very helpful.
    The irony is that this isn't my first rodeo - I installed these same bed lights in my 2014 and didn't have any issues. Help, anyone?
    Cheers!
    :santa:
  2. Dec 25, 2017 at 7:49 PM
    Bob_Lee_Swagger
    Bob_Lee_Swagger Active Member
    18 Tacoma SR
    TRD skid plate, TRD grille, SR5+ gauge cluster
    I would use the actual ground strap bolt as the ground not that screw. Not sure what kind of lights these are or what the current draw is but I'd recommend using a relay if it's anything over a few amps. DMM's are good in some situations, but a test light is much easier to back probe multiple wires. Put the ground clamp on the drivers seat rail mounting bolt and then probe the switch with it on. Test all wires with the switch on. Then turn the switch off and retest all those hot wires. Whichever wire is hot with the switch on and ground with the switch off is what you'll want to tap into for either the relay switched power or the lights main power. Also may be a good idea to retest that wire with your DMM to make sure it's a 12V signal and not a 5V signal.
  3. Dec 25, 2017 at 8:29 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    According to the Toyota instructions you tapped into the wrong wire.
    https://d354nuoz4t18d4.cloudfront.net/b4ebc7b752c2fe024e7feaac4bc89f62/images/custom/install_instructions/00016-34089_TA_16_toyota_mcdonough.pdf
    You want the light green wire on a double cab, and purple on access cab. And since the connector you posted is the smaller one (from an access cab), I’m assuming you’ve either got an access cab and picked the wrong wire on right connector, of you’ve got a double cab and picked the right wire color but on the wrong connector.
  4. Dec 25, 2017 at 8:36 PM
    mrkabc
    Art
    Corona, CA
    Yep... For both of them. DCSB here. Neither wire in the instructions were apparent to me once confronted by the spaghetti in the kick panel. I couldn't see a plug that looked like the one in the pic, so I went to the switch itself. Bad idea?
    Guess I'm an idiot. Any suggestions to find the correct wires?
  5. Dec 25, 2017 at 8:44 PM
    mutely
    Going by the pics you posted and the ones in the instructions, it looks like You got the wrong connector. You are going into the back of the switch, and Toyota want you to use a connector located where your earth is in the kick panel.
  6. Dec 25, 2017 at 9:00 PM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2021 Audi e-tron SUV
    Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    By the cargo light diagram, looks like you tapped one of the door switches which are a ground signal. Also looks like to get power you’ll have to find the light green wire in the kick panel as it appears the switch works off grounds to activate the cargo lamp relay.
  7. Dec 25, 2017 at 10:00 PM
    mrkabc
    Art
    Corona, CA
    Thanks guys, I'll check again tomorrow! :thumbsup:
  8. Feb 7, 2018 at 12:10 AM
    mrkabc
    Art
    Corona, CA
    OK, I have located the correct wiring per the "OEM" instructions. No need to pull the OEM cargo light switch or use any fuse box wire taps. Also, since the bed lights are being run off the OEM relay, you aren't in any danger of frying the switch.
    After you run the hot and ground wires into the cab, pull them into the drivers side kick panel. The ground wire can be attached to the screw directly above the common negative wiring plug using a ring tongue (no need for a wire tap):
    The elusive "green" hot wire that is coming off the relay for the cab lights is located in the white plug nearest the common ground plug (circled in the pic.)
    Pull the white plug out and flip it over. The switched wire to the cargo light is center light green(ish) wire in the middle of the bottom row (when plugged in, it is facing the floor of the truck). There is very little clearance here; it's best to cut away some of the electrical tape and use a wire tap once you get clearance. I don't recommend cutting/soldering/splicing this wire since it appears to be 24 gauge and somewhat fragile. The tap shown (included with the installation kit) does the trick just fine; and this is coming from someone that hates taps.
    Mount the tap and then plug your positive wire from the bed lights into the tap. At this point you can test your lights, they will run right off the cab light switch as intended! The final installation should look like this:
    You can now replace the kick panel and door trim molding. The final result:
    So this is it - success! Hopefully someone who has trouble finding the correct wiring due to cryptic instructions will benefit using this guide.
    Cheers all!
  9. Feb 7, 2018 at 12:17 AM
    hx989
    hx989 Superunknown Member
    Olympic Peninsula
    There are factory bed lights?? Tell me more plz!
  10. Feb 7, 2018 at 12:51 AM
    COSTCOHOTDOG
    COSTCOHOTDOG Well-Known Member
    2018 TRD OR DCSB 6MT
    Glad you got this working! I'll be doing this install next week.
    Apparently, there are 2 bed light kits. One from South East Toyota 00016-34089 (aftermarket but pretty much OEM quality from what I've read) and the actual OEM bed light kit PT948-35160 (double the cost). Don't really know if there is a difference besides price though.
    hx989 likes this.
  11. Feb 7, 2018 at 6:48 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I'd love to have wiring diagrams like that install doc.
    I bet these don't even draw 200ma total. I'd wire them straight in, no relay.
  12. Feb 7, 2018 at 7:22 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
  13. Feb 9, 2018 at 5:15 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Thanks for the follow up. I'm wiring up a dome light in my canopy to operate with the cab dome lights. Similar concept to bedlights. If I'm understanding you correctly, there's really no need to pull a ground (-) wire from the bed if I've already got a ground back there; just the (+). That makes much more sense than the factory instructions which suggest tapping into a ground (-) at the plug in the kick panel. I don't understand the necessity of running a ground wire on a negative chassis ground vehicle.
  14. Feb 9, 2018 at 8:24 PM
    mrkabc
    Art
    Corona, CA
    Yes, sir. My bed lights are grounded to the sheet metal in the kick panel area. I got the idea by looking at the instructions telling me to tap into a black/white wire that plugs into a common gang that's bolted to metal.
    I thought, "why tap the wire? It's all grounded to metal!" It works like a charm.
    Mtn Mike likes this.
  15. May 5, 2018 at 10:36 AM
    advan7
    advan7 Buy once, cry once!
    Orlando & Duuuuuuvalllll!
    2018 Cav Blue Pro
    V2.2021
    Thank you for this post, saved me a few hours of frustration lol. Bed lights wired up and working fine.
    Mtn Mike and mrkabc [OP] like this.
  16. Jan 20, 2019 at 1:34 PM
    TexasTaco4x4
    TexasTaco4x4 Well-Known Member
    Cliffton
    2017 Tacoma TRD 4x4 Sport 6MT
    Thanks for this. I bought two of these and will be working up soon, so appreciate the correct wiring advice!
    https://www.amazon.com/gp/aw/d/B013QLMFA2?psc=1&ref=ppx_pop_mob_b_asin_image
    mrkabc [OP] likes this.
  17. Apr 7, 2019 at 11:45 AM
    abidar
    abidar Well-Known Member
    2016 TRD Sport DCLB 4x4
    Found this thread after effing around for hours with a relay. Thank you for posting this!
  18. Apr 11, 2019 at 6:19 AM
    abidar
    Thanks again. Courtesy and bed lights are awesome :)
    albbak likes this.
  19. Aug 1, 2019 at 11:31 AM
    wyatt45
    wyatt45 Member
    2019 TRD OR DCLB
    Perfect! Thanks for the assistance!
  20. Oct 11, 2020 at 10:32 AM
    albbak
    albbak Well-Known Member
    Al
    Newmarket
    2017 trd sport
    looks good! what underbody lights are those?
