bed light wiring question?
Discussion in 'Lighting' started by TRDfarmerTN, Dec 3, 2011.
  1. Dec 3, 2011 at 12:01 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    if im gna wire up the bedlights to the fusebox, also if i connect to the battery can u do that without disconnecting the battery cable? i dont wanna lose my settings and have to redo the seatbelt alarm thing
  2. Dec 3, 2011 at 12:34 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you are very careful, yes. I don't recommend it though. Any screwup on your part could fry some important stuff.
    Are you running it of the lug on the engine bay's fuse box? That's the way to get the most power to the bed. Then you can tap into that for other additions without overloading. You can also use a relay to switch it on and off with the ignition, if you like.
    Definetly use a fuse as close to the battery as possible.
