Bed light wiring question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WoodsGhost, May 24, 2021.
  1. May 24, 2021 at 10:18 AM
    WoodsGhost
    WoodsGhost [OP] Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Ordered these for my bed.
    Limited-time deal: Nilight - TR-08 8PCS 24LED Rock Light for Cargo Truck Pickup Bed Off Road Under Car Side Marker LED Rock Lighting Kit w/Switch White, 2 Years Warranty https://www.amazon.com/dp/B07YZFN925/ref=cm_sw_r_cp_api_glt_fabc_NBECCZSXH6X5PQS5492C
    Question is, can I get power from any wire in the back so I dont have to run wire to the front?
    I am just putting the switch by the bed outlet.
    Thanks
  2. May 24, 2021 at 10:23 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You could pull power from your #4 pin on the towing connector, (+12V supply).
    Grossomotto, HVLA and WoodsGhost[OP] like this.
  3. May 24, 2021 at 10:28 AM
    WoodsGhost
    PA
    Awesome thanks
  4. May 24, 2021 at 11:13 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Like Ryan said you can use one of the pins on the harness and there's also an extension with an extra 4 pin off the 7 pin that you can use. A few owners use the extension for aftermarket bumpers.
  5. May 24, 2021 at 11:15 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Do you know if that pin is hot all the time or only while the truck is running? Assume its on only while the truck is on? I want to add the factory 20+ bed lights to mine and looking for the easiest way to wire them.
    WoodsGhost[OP] likes this.
  6. May 24, 2021 at 11:30 AM
    caribe makaira
    Caribbean, Puerto Rico
    Only when truck is ON. Turns OFF when all OFF.
    P.S. Verify which "version" connector your vehicle has and test the wire before you T into it.
    Grossomotto likes this.
  7. Feb 10, 2022 at 10:17 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Is this a suitable option for a dash cam to tap into acc 12v? (I would get the trailer plug extension/jumper by curt to actually tap into)
    Dash cam hardwire kit has ground/battery 12v/acc 12v
    Background/story-
    I have 10awg power/ground ran from battery to bed to the fridge outlet. Current plan/thought is to add a fuse box (like the blue seas 6 circuit w/ neg bus) and run the current 10awg into that (mounted in bed) then run the fridge outlet from there while adding options to pull power for other things like bed lights and the dash cam. But to complete the dash cam I need acc12
  8. Feb 11, 2022 at 3:53 AM
    caribe makaira
    The tow trailer battery charging circuit is IGN.
    Dash cam will be facing rearward?
  9. Feb 11, 2022 at 6:38 AM
    baldbeardedtaco
    FL
    Yes mounted on the canopy rear door/window. Thank you
