Bed lights 2 Switches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Mar 29, 2012.
  1. Mar 29, 2012 at 5:23 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    So ive been following this thread
    http://www.tacomaworld.com/forum/lighting/205103-bed-lighting-question-4.html
    and it completely confused me even more.
    What i am wanting to do is have a switch in my cab so i can turn the bed lights on, however i also want to have a pin switch installed so when i open my tail gate it turns on.
    So basically what i am saying is that i want the lights to turn on either way.
    Anyone know how i can do this?
    Thanks
    -Chris
  2. Mar 29, 2012 at 5:23 PM
    CayucosTacoma
    2004 Double Cab 4x4
    But i also want to be able to turn off the bed lights with the in cab switch, for when i have my tail gate open for a long time
  3. Mar 29, 2012 at 5:24 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    3 way switch? On off on...
  4. Mar 29, 2012 at 5:29 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  5. Mar 29, 2012 at 5:32 PM
    CayucosTacoma
    2004 Double Cab 4x4
    ill try to clarify this i guess.
    So I want to be able to push a switch in my cab to turn on the bed lights.
    But i also want to be able to just open my tail gate and have the lights automatically turn on.
    And i want to be able to turn the bed lights off with the switch inside my truck so i can drive with my tail gate down if needed
  6. Mar 29, 2012 at 5:35 PM
    nfs257
    DFW
    She gone
    Right. I think a on-off-on will work if u run one side to a pin switch at the tailgate. :notsure:
  7. Mar 29, 2012 at 5:36 PM
    nfs257
    DFW
    She gone
  8. Mar 29, 2012 at 5:39 PM
    CayucosTacoma
    2004 Double Cab 4x4
    yea i was planning on using a pin switch,
  9. Mar 29, 2012 at 5:43 PM
    CayucosTacoma
    2004 Double Cab 4x4
  10. Mar 29, 2012 at 5:43 PM
    nfs257
    DFW
    She gone
    If you run power from one side of the switch and use the pin to interior the power and the other on side to turn them on full time and the off to bypass and keep them off it should work....?
  11. Mar 29, 2012 at 5:46 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Seems about right, I think.. :confused:
  12. Mar 29, 2012 at 5:54 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Here's a wiring schematic for ya... 2 switches, 1 relay, and a pin switch.
    Personally, safer than running power through switches
  13. Mar 29, 2012 at 6:01 PM
    nfs257
    DFW
    She gone
    Awesome.
  14. Mar 29, 2012 at 8:30 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Awesome, just what i was looking for.
    But what does SPDT and SPST stand for?
  15. Mar 29, 2012 at 8:38 PM
    nfs257
    DFW
    She gone
    Single pole single throw. An on off switch. Single pole double throw. On off on switch.
  16. Mar 29, 2012 at 8:46 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This is the same Idea I used for my LEDs under my doors. Switch in the Up position the LED's are always on (OP's suggestion of tailgating and not wanting to run the battery dead, except always off), Middle position the LED's are off no matter what, and the down position the LED's are controlled by the door pin switches for the Dome light.
  17. Mar 29, 2012 at 8:52 PM
    CayucosTacoma
    2004 Double Cab 4x4
    and for the SPST i couldnt just hook it up to the Pin switch? or is that what you are reffering to
  18. Mar 29, 2012 at 9:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You don't need to use the SPST switch if you don't want to. The only reason you would want that is to be able to turn the lights on from the rear of the truck without opening the tailgate. Seems redundant to me. Rest of the diagram looks good. You need the relay because the pin switch can't take full current to two decent sized lights.
  19. Mar 29, 2012 at 9:16 PM
    CayucosTacoma
    2004 Double Cab 4x4
    might as well throw one in there since i have one laying around. And i figured i might as well use relays.
    Thanks for the help everyone.
  20. Mar 6, 2013 at 1:10 PM
    Dizzy TRD
    Dizzy TRD Member
    North Carolina
    07 TRD Sport 4x4
    BHLM, Tinted Taillights, Debadged, 35% Window tint, Removed mud flaps, LED dome, map and tag lights, 886 reverse light swap, sill protectors, TRD Center caps, Banks Monster Exhaust, Bed lights, D-rings added to front of bed
