Bed Lights Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dizzy TRD, Mar 15, 2013.
  1. Mar 15, 2013 at 11:26 AM
    Dizzy TRD
    Dizzy TRD [OP] Member
    North Carolina
    07 TRD Sport 4x4
    BHLM, Tinted Taillights, Debadged, 35% Window tint, Removed mud flaps, LED dome, map and tag lights, 886 reverse light swap, sill protectors, TRD Center caps, Banks Monster Exhaust, Bed lights, D-rings added to front of bed
    I finally got my bed lights installed after months of stalking threads and ordering pieces. I used a Carling SPDT On/Off/On bed light switch from OTRATTW.com and two Truck-Lite Model 60 Oval lights that I mounted in the bed pockets. I cut out the hole for each light in a sheet of ABS plastic and glued the sheet into the bed pocket. I set the switch up so that when pressed up the lights come on based on opening the tailgate. I installed a door jamb switch at the tailgate to assist with this function. If the switch is pressed down in the cab the lights will come on and will not go off until the switch is flipped back. Overall I am very happy with the set up but I do regret going with the amber and green lights in the switch, Amber and Red would have gone better with the Tacoma interior lights. The bed lights are powered by an add-a-circuit and ran through a relay behind the dash. Let me know what you think and I will try to answer any questions.
  2. Mar 15, 2013 at 11:40 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Mar 15, 2013 at 11:40 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    Clean install very nice!
  4. Mar 15, 2013 at 12:39 PM
    Foxone
    Foxone Well-Known Member
    Very nice, I think Ill give it a try. Care to share some part numbers for the interior switch and tailgate switch?
  5. Mar 15, 2013 at 1:54 PM
    Dizzy TRD
    North Carolina
    07 TRD Sport 4x4
    I used the VVPZC59-1TL V-series Contura V sealed rocker switch from http://www.otrattw.com/proddetail.php?prod=VVPZC59-1TL
    The jamb switch was model SW3677 Courtesy light from autozone ordered in online and they shipped to my house next day for free. There are cheaper jamb switches but I liked the look of the rubber boot.
    I installed it based on this drawing from TurboGT
    http://i1094.photobucket.com/albums/i459/Turbogj/wiringswitch-1.png
    The orange top lights for the switch are controlled by the dash light and the green strip on the bottom comes on when there is power going to the lights.
  6. Mar 15, 2013 at 3:57 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Looks great. Nice job on the switch
  7. Mar 15, 2013 at 4:45 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    Nice clean job! Need to do this.
  8. Apr 4, 2013 at 6:46 PM
    NorCalTaco33
    NorCalTaco33 Active Member
    Ronnie
    Austin, TX
    2012 Tacoma TRD Sport
    Westin Side Steps, Fog light mod, Grillcraft grill, Future Mods: Stowaway Roof Rack, PIAA Lights, Lift 33" tires, UWS Toolbox, and many others...
    Do you know the best way to take out the box to install the lights? I did a very similar mod to my Taco and I broke both the little brackets supporting the box.....
  9. Apr 4, 2013 at 8:23 PM
    racemybuick
    racemybuick Well-Known Member
    Hopatcong, NJ
    07 Tacoma SR5 lots of goodies finally
    K&N filters, 3" front lift toytec, aal with spacer in rear, bull bar, 4" tube steps, ecgs bushing successful!
    I did this:
  10. Apr 4, 2013 at 8:25 PM
    racemybuick
    Hopatcong, NJ
    Lights off:
