Bed Lights
Discussion in 'Lighting' started by CLynch, Dec 3, 2012.
  1. Dec 3, 2012 at 10:22 AM
    CLynch
    CLynch [OP] Well-Known Member
    Charlie
    Upstate New York
    None
    A quick question.
    I am looking to install bed lights. I plan on installing in those useless cubby's. Here is the question:
    Does any one make a retractable spool for electric cable that could fit in there? (small version of the lights that hang from mechanic shops.)
    Typically the lights will always be in there. Flat tire... I have a light on that side of the bed. Need some light as I take a leak. I have a light on that side of the bed. Fabrication is am option but would be cost prohibitive. I understand how the reel works. I just want something to store cable until I need it. About 9 feet x 2 of 14~18 gauge wire to each LED. Thanks for all the help.
    Before the google acolytes tell me to use the internet, I have and I have searched here.
  2. Dec 3, 2012 at 11:42 AM
    CLynch
    Charlie
    Upstate New York
    None
    This is more about cord management than light choice. I am open to all information though. Just trying to clarify for some Pm's I got. Thanks again guys.
  3. Dec 3, 2012 at 3:38 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Late 80's-Early 90's Chevy trucks came with a retractable light mounted under the hood. Perhaps you could adapt that? Maybe throw an LED bulb in there also.
  4. Dec 3, 2012 at 6:38 PM
    CLynch
    Charlie
    Upstate New York
    None
    Sounds good. Will check it out. Pretty much the same idea.
