Bed liner just for the bed rails/tailgate rail
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Feb 14, 2018.
  1. Feb 16, 2018 at 11:22 AM
    chilicoke
    chilicoke Active Member
    Irvine, CA
    01 PreRunner DC
    100% agree with this, another vote for Raptor liner.
    It's all in the prep. Sand/scuff the surface you'll be spraying for better adhesion, etch primer on areas with exposed metal (I used U-Pol Acid #8), take your time and mask. This stuff is messy so definitely plan things out ahead of time
    My Raptor has held up excellent, any 2-part activated liner will be substantially better than air cure rattle can/roll on stuff.
    pheding[QUOTED] and Dalandser like this.
  2. Oct 12, 2023 at 2:24 PM
    Odphadezz
    Odphadezz New Member
    2001 Tacoma
    Nice Thread!
  3. Oct 13, 2023 at 5:00 AM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    Just did this exact same thing, looks perfect and closely matches the Rhino liner. Preparation is the key.
    https://www.amazon.com/gp/product/B07Q69S3RK?ie=UTF8&th=1
    https://www.amazon.com/gp/product/B09YRYFBL4?ie=UTF8&th=1
  4. Oct 13, 2023 at 10:33 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I know ‘great paint’ job is 90% prepping 10% painting .
    for this bed liner stuff…..
    In y’all’s opinion,
    What would be best way to ‘prep’ surface?
    Let’s keep it simple…..rails and top of tailgate only
    (Not full on bed)
    Thanks
  5. Oct 13, 2023 at 11:53 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Sand past clear, prime, mask, spray.
  6. Oct 14, 2023 at 1:10 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Duplicolor has a newer spray that is solvent based about $20 a spray can for smaller jobs:
    Amazon.com: Dupli-Color ETR350007 Premium Truck Bed Coating, Black, 15 oz. : Automotive
    I just cleaned up a rear bumper and painted several coats Rustoleum black and will be spraying it with the Duplicolor above so will see how it holds up.
    Read instructions first of course.
    If used on rusty metal sand and prime using Rust Reformer by Rustoleum.
    Raptor liner 2k spray about $40 in a spray can or many options to roll or get their kit with a spray gun for larger jobs. They have their own special primers so look it up.
