Bed Liner Purpose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InARSticks, Mar 22, 2017.
  1. Mar 22, 2017 at 9:14 AM
    InARSticks
    InARSticks [OP] Member
    NW Arkansas
    2014 white ACLB 5 lug
    2" Ready lift SST, 16X8 ProComp wheels, 255/70/16 Michelin Defender LTX M/S, Extang Solid Fold
    Those that have added a bed liner to to your truck - were you primarily trying to:
    1) protect/strengthen the factory bed?
    or
    2) provide some slip resistance to keep things where you put them?
    or
    3) Other? - explain
    Did you accomplish what you wanted?
  2. Mar 22, 2017 at 9:28 AM
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    I got mine to stop slippage and also because my bed cover leaks. The water runs down the sides and then under the bed mat and out the back. The hope is that things on top of the bed mat stay dry. Has worked so far.
    Edit: I got a bed mat, not a bed liner.
  3. Mar 22, 2017 at 9:30 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Throw a bedmat in the bed and be done with it. I'm not ware of anyone who even makes a traditional bedliner for 2nd gens given it's a composite bed.
  4. Mar 22, 2017 at 9:37 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    just a rubber bed mat to keep stuff from sliding around too much
    I don't care about the composite bed, it is tough as nails. you can scratch it but have to try really hard to break it
    Norton likes this.
  5. Mar 23, 2017 at 4:18 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Keeps stuff from sliding
  6. Mar 23, 2017 at 9:47 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Bed liner does not add strength to a bed.
    HoulaHauler likes this.
  7. Mar 23, 2017 at 9:50 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Blais03 likes this.
  8. Mar 23, 2017 at 10:55 AM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    I have the mat. Probably adds some protection to the bed, but great for keeping stuff from sliding around.
  9. Mar 25, 2017 at 6:02 PM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    Keep stuff from sliding around definitely. That composite material is very slippery.
  10. Mar 25, 2017 at 6:28 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This....You don't need anything else.
  11. Mar 25, 2017 at 6:50 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    T4RFTMFW[QUOTED] likes this.
  12. Mar 26, 2017 at 7:15 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Bed mat...had the same one in a 2006 and 2014. Keeps stuff from sliding and easier to kneel on when climbing around in the back end.
  13. Mar 26, 2017 at 7:54 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Line-X. Seen one a week or two ago that had just been done.
  14. Mar 26, 2017 at 8:09 AM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I'm not talking about spray-on bedliner, I'm talking about those junk plastic inserts people would stick in their 1st gens or any other bare metal truck bed.
  15. Mar 26, 2017 at 8:16 AM
    monsterkx2fiddy
    Oh, I completely misunderstood. I don't know of any companies that make a plastic liner either.
  16. Mar 27, 2017 at 2:04 AM
    Tonk 2014
    Tonk 2014 Expect the unexpected!
    Steelers Country
    PA
    2014 Tacoma TRD Baja TX series DCSB Black
    Reverse light upgrade , Bed extender , stall mat bedliner Indestructible
    I gotta chime in here on this one. I found what they call a stall mat at Tractor Supply for $40 and used a jigsaw to cut out the wheelwells . This stuff is indestructible. It is heavy duty and heavy. Just ask my back. Nothing sliding around on this mat !
  17. Mar 27, 2017 at 3:45 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    That stuff you're trying to keep from sliding around? Tie it down, before it comes crashing through the back window.
  18. Mar 27, 2017 at 2:23 PM
    DallasTX
    2015 4x4 AC
    My truck had a mat when I bought it, but I have used the Tractor Supply mats for other stuff. Agree they are tough, and can surprisingly be cut with a utility knife. I used them as mats under a weight bench and for vibration/sound control under a washing machine.
    Tonk 2014[QUOTED] likes this.
  19. Mar 27, 2017 at 2:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The spray in liners are probably better, but cost a lot more. Even the cheap insert liners do a very good job of protecting the bed from scratches and dents.
  20. Mar 27, 2017 at 3:17 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    My friend had a drop in liner and though it protected the bed from most damage, it ended up scratching up the paint underneath pretty bad, which isn't great since water can collect and then cause rust. He ended up just getting it bedlined. Not to mention I've seen quite a few plastic style bedliners hanging out on the highway after they blew out.
