bed liner ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ji63, Apr 7, 2012.
  1. Apr 7, 2012 at 12:10 PM
    ji63
    ji63 [OP] Member
    Jimmy
    Mississippi
    95 tacoma 4x4 ext. cab
    I am looking at a Taco that has a spray in bed liner. It is a funky tan color and I was wondering if you can paint it. If you can not, is there a way to remove it where it comes over bed cap. I just hate the way it looks.
  2. Apr 7, 2012 at 5:46 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Spray-in bedliners are permanent, so there's no removing it. I'm not sure about painting...
  3. Apr 8, 2012 at 7:54 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    You can remove anything with some elbow grease and a bayflex
  4. Apr 8, 2012 at 8:12 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Spray over the bedliner with a coat of new spray on bedliner?
  5. Apr 9, 2012 at 9:09 AM
    FEARFACT
    FEARFACT Well-Known Member
    03 double cab 4x4
    coilovers,33s etc
    Bed rail caps an option? Look on Autoanything they have quite a few styles that may work
  6. Apr 12, 2012 at 5:56 AM
    baloo
    baloo Member
    N. Illinois
    01 Taco 4dr 3.4L FlexFuel
    FlexFuel Conversion ISR mod DeckPlate Mod TrueFlowAir Filter XM/Sirius ScanGauge II Roadmaster Rear Suspension LINE-X Bedliner LINE-X'd Steptubes LINE-X'd bullbar LINE-X'd fender flares
    Depending on the bedliner, LINE-X has a process called Renew. Basically, they clean up the bedliner, scuff it and give it a new coat. Wouldn't recommend it on any of the crap paint on liners like Herculiner, etc. as LINE-X goes on hot (so it bonds to the paint) and the paint on liners which are notoriously prone to peeling anyway may fail with the heat.
  7. Apr 12, 2012 at 7:34 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    I have Line-X and I love it. Makes throwing shit in the bed so easy... I don't see why you couldn't just paint over it...
    Would rattle can not be an option?
