Bed Mat over Line-X... potential issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jan 23, 2015.
  1. Jan 26, 2015 at 8:24 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I bought some cheap rubber floor mats at Walmart - the cheapest ones they have. It is a soft rubber that can be rolled up and kept behind your seat, not the thick textured mats with the grooves in them. When I load something that might slip I just throw these mats under it. Works great and was probably no more than $10. Mine are a 4-piece set, universal car/suv mats, but there was also a single longer piece for use in vans between the rear seats - these might work better for your use.
    (Also, to get more use out of it, when we camp we use it in the public showers to stand on - you never know who pee'd on the shower floor before you :D)
  2. Jan 26, 2015 at 8:30 AM
    Boerseun
    Ferdie
    Sarasota, Florida
    Also, check the sports department. There are mats that you put under your exercise equipment to protect your floors and keep equipment from sliding around.
    These might not work in an open bed since they are light and might blow off, but in a cap it works great to keep things from sliding around, and it is cheap.
  3. Jan 26, 2015 at 12:20 PM
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    I bought a bed mat from Tractor Supply. Sits on the factory bed floor, zero roll and hardly any cargo slid.
    I've got a tonneau cover and every few months I roll the cover back and pull the mat and let the floor dry. I hardly get any water in the bed and that rolls down and under the mat.
  4. Jan 26, 2015 at 5:04 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    i have diy bedliner and a bed mat. the mat came with the truck. i drilled holes in my bed in for corners. make sure if u do this not to hit anything if u do this. all my cousin in the 10 trucks he has owned has did this. i did mine in july. no problems yet. i dont expect any!
  5. Feb 4, 2015 at 7:02 AM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    Just got this at Walmart. In the exercise section. Was $23.97. Rolls up easy, not too thick or heavy.
