Bed mat rubber stink
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jmd384, Sep 29, 2021.
  1. Sep 29, 2021 at 9:35 AM
    jmd384
    jmd384 [OP] Well-Known Member
    2017 Inferno TRD Off Road
    I know 99.9% of guys won't care about the smell of a bed mat. I'm big into hunting and scent control. Storing my hunting gear in the bed with the mat it pointless as everything comes out smelling like rubber. I've tried scent eliminating soaps, baking powder, and letting it sit in the sun for days. It still stinks like rubber. Short of a post bake oven at 400F for 6hrs, how can I get rid of the smell?
    Sickoreo likes this.
  2. Sep 29, 2021 at 9:36 AM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    simply green cleaner for now..? my bed mat doesn't stink even if dead deer lay on it. The factory rubber smell went away on its own(I use a lowmax cover)
    jmd384[OP] likes this.
  3. Sep 29, 2021 at 9:40 AM
    Mphares2
    Mphares2 Member
    Maryland
    2020 Voodoo Blue TRD Off-Road
    Is it the Toyota bed mat (Rubber)?
    I have the Toyota bed mat and I don't remember mine smelling.
    I would suggest simple green wash and a through rinse.
  4. Sep 29, 2021 at 9:50 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
  5. Sep 29, 2021 at 9:56 AM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Mine had issues at first, but just giving it time has solved the odor problems. Only time I notice anything now is if it's been sitting in 105 ambient heat in the sun with the tonneau closed.
    Canadian Caber, HisDad and jmd384[OP] like this.
  6. Sep 29, 2021 at 10:04 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    This was discussed here not too long ago. If I recall, some said the smell dissipated over time and some said it never really goes away. Mine still has an odor after about a year but it definitely has reduced over time. Full disclaimer; I have the factory tonneau cover on my truck so the bed mat is rarely basking in the open sunshine.
  7. Sep 29, 2021 at 10:07 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Perhaps mine was old stock or something but it never had much of a smell to it other than when it was initially unrolled.
  8. Sep 29, 2021 at 10:08 AM
    Salt Potato Taco
    Salt Potato Taco Well-Known Member
    Tom
    Hudson Valley
    2021 TRD OR DCSB MT
    parking pass, dashboard hula girl, softopper
    Yeah, smell goes away. Mine sits under a solid fold tonneau.
    shakerhood and jmd384[OP] like this.
  9. Sep 29, 2021 at 10:09 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Being that you're "big into hunting and scent control", you should really stop putting your hunting gear on the mat at all. Store everything in scent controlled containers and stop worrying about the bed mat. Any hardware that is too large for contained should be sanitized of scent prior to entering your hunting area.
    wilcam47 and CDV like this.
  10. Sep 29, 2021 at 10:10 AM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    let it spend about a week out in the sun, worked for me
    Old goat1914 and jmd384[OP] like this.
  11. Sep 29, 2021 at 10:18 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    My Toyota oem bad mat stunk for months just need to let it sit in the sun and eventually the smell goes away .
  12. Sep 29, 2021 at 10:27 AM
    auk
    auk Well-Known Member
    Dave
    Let it sit in the sun for as long as you can. A good scrub before and after should eliminate the smell.
  13. Sep 29, 2021 at 10:31 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Mine still has a bit of an off-gas smell after about 2 months, I do have a cover on the bed.
    Hauled half a yard of compost in it a bit back that seemed to help a lot, got another load or 2 to haul
    over the next few weeks. Doesn't bug me tho.
  14. Sep 29, 2021 at 10:33 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    you could try putting the bed mat in an enclosed space with an ozone generator. don't run it too long though as ozone can oxidize (everything).
  15. Sep 29, 2021 at 10:35 AM
    jmd384
    Yes, it is a toyota bed mat I ordered from a dealer over labor day.
  16. Sep 29, 2021 at 10:38 AM
    jmd384
    Nice. How long did it take? I'm a couple weeks out
  17. Sep 29, 2021 at 10:45 AM
    jmd384
    Thought about putting it in the bed with ozonics plugged in and the tonneau cover closed. I think it's going to take heat and time. Like it's unreached monomer from when the rubber was vulcanized. Unfortunately I got it after the hottest time of year. I did smell it baking on my driveway today even though it's 65F . Hopefully the sun does the trick
  18. Sep 29, 2021 at 10:46 AM
    jmd384
  19. Sep 29, 2021 at 10:49 AM
    jmd384
    I wash the bed and trifold. It's not practical to pack my climbing sticks, treestand, and climber into a scent proof container. Nor is it practical to wash them every time I go out. It's an unnecessary step (unless the bed mat makes them stink) that will result in wet straps and a wet butt. Plus I don't see it working out well. My hunting spot isn't close by and I currently don't have a camp or running water. Wash it at home and it will probably just pick up more stench while driving. I'd rather let them slide around a little and not use the mat, but that defeats the purpose of buying it.
    OhNoItsMe likes this.
  20. Sep 29, 2021 at 10:52 AM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    I think they must have changed the formula in their rubber. My bed mat smelled mildly of rubber when I first took it out of the box, but after that I never remember smelling it at all. I bought it about 2 years ago.
