Bed material durability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Groan Old, Mar 3, 2018.
  1. Mar 3, 2018 at 9:28 AM
    Groan Old
    Groan Old [OP] Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    New owner of a 2011 Tacoma. I know the bed is a composite material of plastic and fiberglass; how durable is it to continuous abrasion from shoveling (as in removing dumped material from the bed) and impact resistance (such as a dropped cinderblock)? Mine will be a working truck as well as my daily driver. I've moved down a bit from my last truck, which was a one-ton crew dually; didn't need such a behemoth any more but still need to haul stuff, albeit on a smaller scale. It's going to be difficult to adjust from a 5x8 foot bed to a 4x5 foot one
  2. Mar 3, 2018 at 9:30 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Tacoma bed is meant for light duty. Dropping cinderblocks and the such is going to tear up that bed in a hurry.
    ChadsPride likes this.
  3. Mar 3, 2018 at 9:31 AM
    Groan Old
    Ken
    Newton NC
    Kind of what I thought. I've been considering putting a hard tonneau on it, looks like that will be the plan and a trailer will get the "hard hauling" duties.
  4. Mar 3, 2018 at 9:32 AM
    Iamraiderpower
    Probably the smartest thing
  5. Mar 3, 2018 at 10:06 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    I used the bed mat as pattern for cutting plywood to lay down in the bed before hauling sand , gravel and mulch. Makes for clean, easy shoveling back off. I used 1/4" plywood, since I had it handy. Just make sure that the piece in the back overlaps the front piece by a couple inches ,so it doesn't catch your shovel, when shoveling off loose materials
    Stryker420 likes this.
  6. Mar 3, 2018 at 10:07 AM
    badger
    badger Well-Known Member
    07 SR5
    Mine has held up to a lot of thrown firewood and heavy loads, but cinder block is asking a lot. I'm frankly very impressed with how tough it has been, and completely rust free :)
    Markcal likes this.
  7. Mar 3, 2018 at 12:29 PM
    Groan Old
    Ken
    Newton NC
    Sign of the times, I guess, moving to lightweight, non metal material, but a good spray-in bedliner will take care of rust issues, at least from the inside. had one in the dually, was great.
    This truck looks so nice, I don't want to mess it up by getting it dirty. Gotta stop being a wuss and use the thing for what it's designed for........FUN.
  8. Mar 3, 2018 at 12:33 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    It’s ok to be a wuss until you get your first scratch.......then it’s game on after that !
    desertrunner24 and airsavage like this.
  9. Mar 3, 2018 at 7:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's tougher than you think. Mine is going on 11 years old without any issues. No more weight than these little trucks can handle won't hurt the plastic bed. Probably tougher than Fords aluminum :thumbsup:.
    Of course I also use a trailer. I figured out real quick after coming from a 1/2 ton that the beds are so small on these trucks, and the payload so low that I'd need a trailer for any real hauling. I can put twice as much weight on my 8X10 trailer as I could carry in an 8' bed in a 3/4 ton truck and it is a lot easier to load and unload.
  10. Mar 3, 2018 at 7:53 PM
    Pigpen
    Dan
    Northwest Montana
    Why throw cinder blocks, even into a steel bed. It would still cause severe wear and tear. I always protected steel beds with plywood, even for firewood - I've dented steel beds. I use my truck as a truck, but I still try to take care of it.
    Naveronski, DGXR and IronPeak like this.
  11. Mar 3, 2018 at 8:31 PM
    Groan Old
    Ken
    Newton NC
    It's not that I'd throw cinder blocks in any truck bed, but sometimes heavy stuff gets dropped, or falls over. Just wondered how much the composite could take. I wouldn't dream of putting this truck through what I did with the dually. I once went to a quarry for some crusher-run gravel, told the guy to fill the bed about half full, he dumps gravel in with a huge bucket, the load is above the inner fender humps. When I cross the scales, I had 3100 pounds of gravel on board, and the truck was sitting on the bump stops in back. Luckily I only had about 5 miles to drive.
  12. Mar 3, 2018 at 9:51 PM
    Pigpen
    Dan
    Northwest Montana
    I has a similar experience picking up a load of manure. They guy did me a favor and gave me a little extra. Like 3 yards instead of 1. I rode home on the bump stops. All the flower beds, fruit trees, garden, etc got more fertilizer than I really wanted to put on. This was in a one ton, not the Taco.
  13. Mar 4, 2018 at 6:57 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I did the same as well still figuring it out but I have the 6ft bed. I wouldn't toss cinder blocks in it or be as rough as you were with the steel bud but they are pretty darn tough and can take a moderate amt. of abuse. They don't dent where my old truck dented from things I use to do. I have had some pretty heavy stuff slide around or fall over and nothing has happened.
  14. Mar 4, 2018 at 6:56 PM
    Groan Old
    Ken
    Newton NC
    This is another thing; I had a sprayed-in bedliner on my last truck, you could leave the tailgate down and not worry about stuff sliding out; this one is like the plastic drop-in's, slick as ice. I do like the sliding tie down clamps at the top of the bed and the tie-down rings at the back corners.
  15. Mar 4, 2018 at 7:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    A bed mat will give more grip than you can imagine. As well as a great amount of protection against abrasion.
    In fact it has so much grip that I remove it to haul mulch, because the shovel doesn't slide very well.
    I also remove it to haul shipping boxes that I have to slide in because they are too heavy to lift in place.
    I have an OE mat, but some folks make theirs out of horse stall mats and like them a lot.
  16. Mar 4, 2018 at 7:14 PM
    boudain
    boudain Well-Known Member
    Bobby
    South Texas
    2015 DCSB TRD Off Road 4x4
    TRD Sport Scooped hood...for science!
    You'd be surprised at how durable the SMC bed is. I've had gravel, rocks, mulch, and dirt in the back of mine. When picking up wood chunks I've tossed them carelessly back there with no problems. I've hauled a small upright piano in the back without issue as well. By all means don't throw cinderblocks back there, or back in any truck for that matter, but don't feel like you have to baby it.
  17. Mar 4, 2018 at 7:23 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I did the same, had gaps enough to take a hose into the bed and flush out any material that got underneath the plywood. And no rust drilling into the composite.
    I put a Home Depot 4x6 outdoor rubber mat on top of the plywood to defeat the sliding.
  18. Mar 5, 2018 at 3:08 PM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    I haul between 500 and 1000lbs of bricks and mine does fine. Once had 1800lbs of bricks and was on the bump stops. Put a bed mat in it to keep it from sliding around and cut down on the scratches.
  19. Mar 5, 2018 at 3:14 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The truck bed will look horrible after a lot of use.
    Should hold together fine, but won't look good.
    If you are going to use your truck as a work truck I would worry more about your leaf springs. You'll probably be looking for a new set after a few heavy loads. So just budget those and you should be OK.
  20. Mar 5, 2018 at 6:28 PM
    Groan Old
    Ken
    Newton NC
    Can you get a set of overload springs you can add, and longer U bolts? You're saying the stock springs will lose their shape if you overload them?
    I've pretty much decided that if it's heavy, sharp or dirty, it'll go in a trailer behind me. I bought a hard tonneau cover today for it, one that folds back in thirds. It's a top mount, the flush fit rails take up too much space for me. I'll post pics later, it looks pretty good.
