Bed Molle Panels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daveeasa, Jul 10, 2020.
  1. Jul 10, 2020 at 11:49 AM
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I did some quick searching and didn't see anything obvious but if anyone can point me to a good thread on this topic, much appreciated.
    I have a short bed w lomax tonneau cover and recently installed a mountain hatch because sitting on the factory tailgate for an extended period was a little less comfortable than I expected. I have two small boys who apparently really like to play in the truck bed. I have a bed mat so seating is super comfy now but the side rails aren't all that back-friendly.
    I'm contemplating this:
    https://caliraisedoffroad.com/colle...ucts/2005-2019-toyota-tacoma-bed-molle-system
    My questions:
    1. Does anyone know of a molle mounted (or direct rail mounted) seatback cushion or cushion of any sort which might space my back away from the tonneau rail (boy does that question make me feel pathetically old)? I'm thinking I can probably cobble something together from any old cushion and some brackets.
    2. Are there other options for side molle panels than this manufacturer which I should look at?
    3. It looks like this model blocks the entire rail but their other model (which doesn't block the rail from cleats) supposedly doesn't work with a tonneau cover? Does anyone have a side molle panel who might comment on the differences/specifics? I'm thinking this model is spaced further away from the side so it clears the brackets which connect to the tonneau rails?
    4. Are there any downsides to adding a molle panel to the sides other than potential loss of rail use?
    donp likes this.
  2. Jul 10, 2020 at 3:49 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
  3. Jul 10, 2020 at 4:02 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    I have a roll n lock. The screw towards the cab was a pia to set up but I don’t think tonneau equipped trucks to have that problem.
    daveeasa[OP] likes this.
  4. Jul 10, 2020 at 4:42 PM
    daveeasa
    David
    PNW
    I was thinking, I can just put some molle pouches and stuff them with rope/tie downs / bungees and I get comfy back _and_ easily accessible gear retention, a win-win.
    Blackbeard83 likes this.
  5. Aug 8, 2021 at 6:58 AM
    daveeasa
    David
    PNW
    Well, interestingly, the victory4x4 molle panels I ended up buying won’t work easily with the Leer 100xq shell I put on yesterday. The bolts don’t line up properly with the rails spaced away from the sides using Victory’s brackets.
    I think I will end up buying the Caliraised panels and selling the Victory ones. Which is a small bummer but hey, live and learn.
  6. Aug 8, 2021 at 10:43 AM
    kderp
    kderp Well-Known Member
    Phila PA
    2021 Tacoma TRD Bro
    I have BuiltRight’s panels, which mount under the rail. Works perfectly great with my LoMax tonneau. 0B38D117-8273-4FD7-9C26-7AB66A8F9E4C.jpgED4F71AD-D222-403F-9EE5-99DD2D600CAA.jpg
  7. Aug 8, 2021 at 11:16 AM
    daveeasa
    David
    PNW
    Yeah, my Lomax worked great with the victory molle. It’s just the Leer which has very precise tolerances. I’ll need to restore the lateral position of the bed rails which eliminates victory or any rear mount option. The leer shell mounting scheme is great in some ways but it blocks some of the utility of the rail at the same time.
  8. Apr 24, 2022 at 1:36 PM
    BuiltRight Industries
    BuiltRight Industries BuiltRight Industries
    New Milford, CT
    2020 TRD OffRoad
    Looks so clean!
  9. Apr 24, 2022 at 2:59 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i went with the ebay molle panels, but i'm a long bed. also can't tell you how they work, i'm in the process of modding them to suit my whims, which aren't fully determined!
    is that an air tank and compressor setup?
  10. Aug 20, 2023 at 11:50 AM
    jcbasile
    jcbasile Active Member
    Connor
    SoCal
    2023 Tacoma TRD Offroad 4x4
    Late question, just got a Lomax tonneau and was going to go with Builtright molle panels as well. Does installing the panel behind the bed utility rail make the tonneau cover less water proof or has it impacted using the lomax in any way?
  11. Oct 17, 2023 at 12:02 PM
    New Milford, CT
    2020 TRD OffRoad
    Hey - how'd you end up making out?
  12. Oct 17, 2023 at 1:13 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Cheap lounge chair cushions! You can just use an adhesive and glue Velcro tabs to them or sew on some ties. Plus an old tv mount as “free ghetto molle.” Consider a thin plywood sheet too so you can make it recline.
    daveeasa[QUOTED][OP] likes this.
  13. Oct 17, 2023 at 1:14 PM
    jcbasile
    Connor
    SoCal
    Worked out great! Definitely a bit more space in between their mounting bracket and the bed wall but so far doesn't seem to be impacting the water proof lining. Granted it doesn't rain much in SoCal, but I have taken it to a carwash using a pressure washer directly there and didn't see any water in the bed so I would say success with Lomax tonneau so far and can update again later down the road.
    Looks like it is time to order the other side and back lol!
  14. Oct 18, 2023 at 6:03 AM
    New Milford, CT
    2020 TRD OffRoad
    That's awesome. Glad to hear. I was thinking if you do ever have a leak issue a rubber sealing bulb with a wider profile might be a quick fix.
    jcbasile[QUOTED] likes this.
