Bed mounted ARB dual compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Powder taco, Mar 11, 2018.
  1. Jun 9, 2018 at 3:00 PM
    #41
    MTNyota
    MTNyota Well-Known Member
    Gray 2017 TRD OR
    All good thanks, I ended up mounting mine to the underside so I can keep the hose in the box. We’ll see how it does with the dirt down there..
  2. Jun 9, 2018 at 3:01 PM
    #42
    Powder taco
    Powder taco [OP] Well-Known Member
    Brent
    Everett, WA
    17 TRD Off-Road
    Solid looking install, I am sure it should hold up pretty good.
  3. Jun 11, 2018 at 8:37 AM
    #43
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    How much road grime, mud/dirt, or water gets into the box. Have you taken this setup off road yet?
  4. Jun 11, 2018 at 8:55 AM
    #44
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    You can fit a single in the box without modification as said by @Powder taco I'm currently working on that install myselfIMG_20180609_135017.jpg
  5. Jun 11, 2018 at 9:04 AM
    #45
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    Educate me please. What is the reason for having an air tank? Doesn't the compressor put out enough pressure to air up tires? Or is it for using lockers? Also, do I need a twin or is a single enough just for tires? I'm planning an ARB as my next project.
  6. Jun 11, 2018 at 10:53 AM
    #46
    micwillia
    Cental Masshole
    I believe the single is all that is really needed for only filling tires. Some people will go with the twin to fill larger tires, more tires, or longer duty cycle. I'm working on my install of a single so I don't have fill times but the data shows it should be fine in less time than the duty cycle for the single.
    HoboDave[QUOTED] likes this.
  7. Jun 11, 2018 at 11:16 AM
    #47
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    Not sure if you can answer this or @Jeff-exe (how do you @ someone with an @???) Expedition Essentials , but is there a reason to mount it with the wires down instead of up? I thought if I did wires up I'd be able to replace the filters without having to unscrew the entire setup.
  8. Jun 11, 2018 at 11:26 AM
    #48
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
    Yes i taken it off-road, both in muddy and dusty conditions. The box has drains in the bottom, you will not have to worry about standing water. It is high enough up in the fender that it really is not an issue.
    You are correct, the compressor is fine by it’s self. I installed a tank for a few reasons, I will run a front locker in the future, I want to install an air horn and I wanted the ability to run power tools.
  9. Jun 14, 2018 at 3:35 AM
    #49
    Jeff@ExE
    Jeff@ExE Well-Known Member
    Jeff
    2016 Toyota Tacoma
    A Lot
    You can mount the compressor the other way, it will not affect performance.
  10. Jun 17, 2018 at 11:02 AM
    #50
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    My next project! Solid work!
    Powder taco[OP] likes this.
  11. Jul 11, 2018 at 12:22 PM
    #51
    babyruth
    babyruth Well-Known Member
    '17 Super White TRD Offroad Taco
    @Powder taco did you choose to keep the isolation switch and ditch switches 1 and 2? Why and which wires did you attach the ignition and dash wires to so they go to the plug in fitting?
  12. Jul 11, 2018 at 12:58 PM
    #52
    i8boots
    UT - 801
    I learned the hard way that the ARB harness only hooks to black and purple from the compressor. One is the sense wire, one is the ground(black). Shorting the two does not activate the compressor. You need to add a separate ignition wire (12+v) to send power to the purple wire to activate the compressor. Removing 12v from the purple wire will shut off the compressor.
    I'm actually quite disappointed in ARB as my compressor cabling had black (ground) purple (sense) and red (12+v) going to the plug on the harness on the compressor side, but none of their other wire harnesses pulled the 12v from there and expect you to wire in a different 12v source. It's right there, why not include it in the harness?
  13. Jul 11, 2018 at 1:04 PM
    #53
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    What you said is over my head but I want to know what you're talking about. I'm in the middle of putting my extension harness together and I hope I did it right.
  14. Jul 11, 2018 at 1:12 PM
    #54
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
    I removed 2 of the 4 wires from the compressor, leaving only the purple and black. I just followed the wiring diagram and connected only those 2 wires to the existing harness.
    babyruth[QUOTED] likes this.
  15. Jul 11, 2018 at 2:49 PM
    #55
    babyruth
    Are y'all keeping the ARB harness in the engine bay and extending power and pressure switch to the bed? Or running extension from battery and cabin switch to the harness in the bed?
  16. Jul 11, 2018 at 6:37 PM
    #56
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
    Yes the main harness is in the engine bay and I use the expedition essentials extension harness.
    Tayoflor, Jeff@ExE and Frito like this.
  17. Jul 16, 2018 at 10:21 PM
    #57
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    Did you have issues with the factory thread rivits from letting the EE cubby mount flush to the bed? Seems like I am...
  18. Jul 17, 2018 at 3:33 AM
    #58
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I tried to tackle this project on Saturday. I followed the template, drilled and then discovered the rivets were in my way when I tried installing the compressor/mount. I used the bar that affixes from the outside as a guide above the rivets and re-drilled...ran out of the extra set of hands to try to re-install the compressor/mount.
  19. Jul 17, 2018 at 4:37 AM
    #59
    Jeff@ExE
    Jeff
    2016 Toyota Tacoma
    A Lot
    Alec: you may be in a similar situation as Paul was, might be just a little high with your location of the holes, the flange should sit just below the factory threaded inserts.
  20. Jul 17, 2018 at 9:50 AM
    #60
    i8boots
    UT - 801
    I tried to center the template exactly both right/left and both top / bottom. I may (if I did it again) have wanted to move it up higher. Even then I had holes that did not align perfectly and I ended up doing last minute re-drilling on my right side (since my left had metal behind the composite bed).
