Bed mounted winch ideas for pulling up heavy stuff?
Discussion in 'Technical Chat' started by red8, Nov 7, 2022.
  1. Nov 11, 2022 at 4:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’d build a structure mounted to the two front most bed mounts and have a winch plate welded to the top. Have it triangulated to counteract the winch force and it could be removed with a simple lynch pin or on of those QD tube clamps.
    Bivouac likes this.
  2. Nov 26, 2022 at 5:45 PM
    lbhsbz
    lbhsbz Well-Known Member
    Maybe I'm not understanding....the only way I've ever loaded a bike into a truck was to push it. Sometimes with the help of a buddy, sometimes with a running start.
    How do you typically get it up the ramp? If it rolls, a simple bridle between the front tie downs and a pulley (maybe doubled up)...one person to pull on the rope and one to hold the bike up. Or get one of these a remote and you walk the bike up while it pulls.
    The existing tie downs are plenty stout to handle the relatively low force required to pull a rolling bike up a ramp.
    If you're dragging it up on it's side, that's a different story. But at that point, you'll probably have all the help you need if you've managed to wad it up that bad.
