Bed Mounting Rail System - Is terrible!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Duburban, Jun 26, 2019.
  1. Jun 26, 2019 at 5:17 PM
    Duburban
    Duburban [OP] Member
    This system is just the worst...
    Its great right, until its not. I just took off a bed cover because this rail system wont allow me to run trac rac AND a bed cover at the same time.
    While removing the screws holding the rail/bed cover I stripped 2 on each side. The brass insert in the plastic just spins. Now I have a major percentage loss of holding power. At this point I'm thinking to fasten through the face of the trac rac system through the metal bed rail and a support strip of steel sandwiched up under the metal bed rail.
    Anyone deal with this disaster ?
  2. Jun 26, 2019 at 5:23 PM
    tcjacado
    tcjacado Well-Known Member
    Cant you just lower the bed rail to a new location below the rack mounts.
    Blais03 and Gunshot-6A like this.
  3. Jun 26, 2019 at 5:24 PM
    Duburban
    Not sure if I follow you but if I use any new hole locations then I won't get the benefit of the brass insert in the plastic bed liner.
  4. Jun 26, 2019 at 5:27 PM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Been there done that. Pain in the a$$! I had two strip total and it took me awhile and a 3rd hand to get them to finally unthread. I drilled new holes and said eff it.
  5. Jun 26, 2019 at 5:27 PM
    tcjacado
    Your going to have to grind those heads off to remove the rail completely now that they are just spinning. Just be careful on the driver side not to hit the gas filler neck.
    Gunshot-6A likes this.
  6. Jun 26, 2019 at 6:19 PM
    Duburban
    good tip!
  7. Jun 26, 2019 at 6:49 PM
    Duburban
  8. Jun 26, 2019 at 7:55 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Can't remember who makes them, but for the price I think I'd rather have stiffeners with a longer lower leg.
  9. Jun 26, 2019 at 8:02 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    No, I'm Jeff B.
    rmorse and WATaco like this.
  10. Jun 26, 2019 at 8:04 PM
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
    Jeff B. was here first
    jeff b likes this.
  11. Jun 26, 2019 at 8:05 PM
    Duburban
    My primary concern is loading the truck rack with lumber. I've gone far enough on this project to know that the truck isn't made for it so I'll never overload it. But still... 2 screws down on each side isn't great.
    I will try to draw up some details of what I'm thinking about building.
  12. Jun 26, 2019 at 8:09 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Fiiiiine
  13. Jun 27, 2019 at 6:08 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
  14. Jun 27, 2019 at 6:16 AM
    Duburban
    I logged in for this...?
  15. Jun 27, 2019 at 6:17 AM
    rmorse
    Bobby
    Bowie, MD
    Jeff.
