Bed Plug Not Maintaining Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PapermanX23, Sep 4, 2024.
  1. Sep 4, 2024 at 8:05 PM
    PapermanX23
    PapermanX23 [OP] Member
    When plug something into my bed 110v power outlet and turn the appliance on (this case a vacuum cleaner) it powers for a second then turns off. I press the button in my cab to turn it on. It turns back on and the vacuum turns on, but only for a second and it turns off again.
    Has anyone had this problem? If so, what was the root cause and how did you get it fixed?
  2. Sep 4, 2024 at 8:15 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like your trying to pull more power than it can supply, it's only a 400 watt inverter most vacuums pull more than that.
  3. Sep 4, 2024 at 8:17 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Your vacuum cleaner uses more than 400 watts.
    If you are parked and have the engine running you can plug in up to 400w. If you are driving that drops to 100w.
    It's pretty limited. You can do the "400 watt anytime" mod, but you can't pull more than 400w from your stock inverter.
    PapermanX23[OP] likes this.
