Bed Rack Lights
Discussion in 'Lighting' started by dustinclm, Nov 11, 2013.
  1. Nov 11, 2013 at 9:14 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    So i made a bed rack this past week and would like some suggestions on what lights to mount to it. Im not looking to spend $100's on top notch lights but something that will be sufficient out to 20-30 feet. Mainly for backing up my boat or light for cleaning deer at night. I'm guessing a flood style light or a LED light would work best. I have read that the 6LZ LED Compact Light Bar works well
    For you guys who have lights on a rack, did you run the wires through the tubing down to the bed and into the cab?
  2. Nov 12, 2013 at 12:49 PM
    dustinclm
    Thibodaux, La
    Bump. No one has a lights installed on their bed accessories or bumpers?
  3. Nov 12, 2013 at 12:58 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I have a bar but no lights yet. I plan on installing a set of duallies so I can change filters as needed. A bit over kill but hey, why not
  4. Nov 12, 2013 at 1:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've seen some trucks on here that have bed lights but they are the regular square kind of cheap ones you can buy at Wal-mart. I'd say since you built a nice custom rack to stick with some nice stuff and go LED or something along those lines to make it all look uniformed and pretty haha.
  5. Nov 12, 2013 at 1:09 PM
    dustinclm
    Thibodaux, La
    Thats the mindset i am going with too but im also trying not to over spend. I am getting it sandblasted for free through work along with $15 for zinc chromate primer and some cheap herculiner from an auto store will save up a little for some nice lights. I also bought some air springs so that dropped my budget for my lights
  6. Nov 12, 2013 at 1:13 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I see what your saying and I'm sure there is something out there that isnt to expensive that will work for you just have to search and keep your eyes peeled.
  7. Nov 12, 2013 at 1:17 PM
    dustinclm
    Thibodaux, La
    Yeah, i just wanted some 1st hand feedback because i dont want to buy some lights and then i cant see past my 20' boat when going into the back yeard.
  8. Nov 14, 2013 at 9:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have owned a few sets of cheap lights.
    I currently have a $40 set of slim fog lights from Kragen Auto under my rear bumper. They are fine for backing up in dark areas, but I would not want to use them to see past a 20 foot boat and trailer.
    I have also owned standard "PAR 36" 35W sealed beam lights commonly available in Harbor Freight, NAPA, and truck dealerships. They come in a rubber housing and are about 4 inches in diameter. The ones I had were "tractor beam" pattern. They were a little bit too diffused to be useful past 20 feet IMHO. There are many different sealed beams that will fit into a PAR 36 housing, including 100W aircraft landing lights. :eek: Never did try those, but I am told they throw light all over the place.
    What I would recommend is something like this: http://shop.advanceautoparts.com/we...ing-light-kit-blazer_6250350-p?zoneAssigned=1 I had a set of those as backup lights on a past truck. They would satisfy the 20 foot requirement. They are referred to as a driving light pattern, but there were terrible at any kind of speed, didn't project far enough out to be of any more use than my high beams. But at low speeds they were fine, that's why they got moved to the rear bumper.
    Try to get a plastic housing. Anything metal in the "inexpensive" range is going to have cheap paint and chrome on it, and will rust fast.
  9. Nov 14, 2013 at 11:13 PM
    Blitzpro
    Blitzpro Well-Known Member
    The 6LZ would be a perfect fit since it will match the low profile of the rack, light up the area you need and won't break the bank.
  10. Nov 18, 2013 at 8:22 AM
    dustinclm
    Thibodaux, La
    Thanks for the info/pics. Im leaning towards getting the 6LZ
