Bed rack tent combo advice...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MemphisTaco08, Nov 29, 2021.
  1. Nov 29, 2021 at 10:52 PM
    MemphisTaco08
    MemphisTaco08 [OP] Well-Known Member
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    3/1 lift 33in tires Overland Yakima system with Yakima Skyrise HD2
    Sup folks,
    Looking for a budget/affordable overland bed rack (or rails?) and RTT (liking smittybilt gen2 so far) for my 07 trd sport...
    I do a lot of hunting, primarily deer/squirrel/coon. Many places I camp have awful ground camping areas, hence the need for rtt. I need to be able to throw a deer or dog box in back. Also would like to strap Jerry cans (water/fuel/coffee) and rifle case to rack. Recovery is not an issue currently as I'm primarily at a farm or on gravel roads. Would also like the ability to easily remove rack/rail (and possibly raise/lower it?) in case wife asks me to pick up some furniture on weekend or I have to load daughter's power chair.
    Probably a tall order for "budget" but you guys always seem to have some great ideas. Thanks in advance for suggestions!
  2. Nov 29, 2021 at 11:05 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    I just tie a tarp over my bed can’t imagine spending all that money on a rtt and driving around with that monstrosity on a daily basis.
  3. Nov 30, 2021 at 5:12 AM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Valid point, but not planning on leaving rtt on daily. Primary reason I was asking about a rack that could be removed, if that's an option?
  4. Nov 30, 2021 at 5:22 AM
    Coldfuzion
    Coldfuzion Active Member
    Andrew
    2018 Beige Tacoma TRD Sport 4x4
    Prinsu Rack, more to come
    I was running my smitty gen2 xl on my rsi cap but moved it to my m1101 trailer build. Found these cheap racks on Amazon and they work great on the trailer but they are designed for pickups. https://www.amazon.com/dp/B0716L9MTJ?ref=ppx_yo2_dt_b_product_details . Just some ideas for ya, love that tent especially being 6'5". Rack is easily removable with some allen bolts to remove the entire top section in just a few minutes.
    MemphisTaco08[OP] likes this.
  5. Nov 30, 2021 at 6:11 AM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Thought about a trailer set up, but wanting to pull boat on fishing trips.
    How sturdy is the tent floor with only the 2 parallel bars?
    Probably need to mod the bars to accommodate anything like cans or cases?
  6. Nov 30, 2021 at 6:21 AM
    Coldfuzion
    Andrew
    Mines been rock solid either with the two bars on the rsi cap or with the TMS bars on the trailer. I have the tent on half the rack so that the fold out side over hangs and I can use the annex. You could use the other side for cases or cans, could make a small plywood platform with ubolts to hold it down then mount the cases to the board.
    This is the build I'm working on copying / tweaking for my own:
    https://www.youtube.com/watch?v=3z9HEVbMV6Q&ab_channel=bradhrynko
  7. Nov 30, 2021 at 4:51 PM
    N8tiveTaco21
    N8tiveTaco21 Well-Known Member
    Central Washington
    '10 TRD OR
    OME Dakar leaves, 886 springs, SPC UCAs, Softtopper, GFC Superlite, Caliraised Rock sliders, 4.56 regear w/ Eaton Elocker
    If you or a buddy has a welder, build a rack. I bought the metal and spent some weekends in the garage cutting and grinding. The material came out to around $300 and is removable. It isn’t height adjustable though 20C2F35D-BC07-48D9-9520-5EE00FE62BFF.jpg20C2F35D-BC07-48D9-9520-5EE00FE62BFF.jpg DB802211-687C-4423-9C31-AA08055F8C71.jpg
  8. Nov 30, 2021 at 5:45 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Watched some more youtube vids, seeing that most of these racks fit into the side rail system should make them easy enough to remove if needed. May be able to hit up a buddy for some welding. Thanks!
    N8tiveTaco21[QUOTED] likes this.
  9. Nov 30, 2021 at 5:59 PM
    10YSON
    10YSON Well-Known Member
    GREG
    2ND GEN 4X4 LT
    TOTAL CHAOS 4WD LT KING SHOCKS TOTAL CHAOS SPINDLE GUSSETS TOTAL CHAOS CAM GUSSETS EXTENDED SS BRAKE LINES TOTAL CHAOS SPRING UNDER KIT DEAVER SPRING UNDER LEAFS PRP SUEDE STEERING WHEEL KMC CANYON 16X8 315/75R16 DIY FRONT & REAR BUMPER DIY BED RACK & SMITYBILT RTT EBAY SNORKEL SOME LIGHTS & OTHER SHIT
    All Pro makes some cheap bed rails that are like $100 each
  10. Nov 30, 2021 at 8:54 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Max Modular
  11. Dec 3, 2021 at 8:25 AM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    After hours of research, I'm leaning toward splurging and letting the wife chew me out. Yakima looks like everything I want in a tent and system. Easy setup/take down and looks like it is removable as well. Anyone have any knocks on skyrise hd or the outpost?
  12. Dec 3, 2021 at 8:28 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Our customers use the Skyrise all the time, it's very popular and they seem to love them.
  13. Dec 3, 2021 at 11:07 PM
    TacoTuesday1
    SoCal
    get the @fortoverlanding load bearing soft topper from costa rica to flex on literally everyone
    their latest ig post says price $575
    even cheaper than softopper...
  14. Dec 4, 2021 at 12:27 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Simple, clean, and effective.
    CBI overland bars
    23Zero Walkabout 56
    8 Bolts remove the bed rack and tent using my garage hoist to store on the ceiling. Takes 10 minutes if I need bed space.
  15. Dec 4, 2021 at 6:12 PM
    jjmead1
    jjmead1 Active Member
    2009 Tacoma access cab TRD
    Sorry man, I cannot abide by this. I own one and it is falling apart. Contacted them and they will not do anything. Your rack system deserves far far better than the Skyrise.
  16. Dec 4, 2021 at 6:30 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Do you have the regular skyrise or the HD?
  17. Dec 4, 2021 at 11:35 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    What I'd say is throw in your dog box and measure what you need for clearance. Find a local guy to build you a rack to meet those needs. I can build you a rack, I see you're in TN, shipping probably kill the deal but I have friends that live in Ooltewah so I could bring it by next time I'm down that way which would be a few months.
