Bed Rack with Tonneau
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VirusCage, Aug 17, 2017.
  1. Aug 17, 2017 at 7:00 PM
    #81
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    From the looks of it, if the kbvoodoo rack was about 4" shorter front-to-rear, you could open the last panel of the OEM tonneau.
    I bet just using the short bed version would work for those with a long bed.
  2. Aug 17, 2017 at 7:02 PM
    #82
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This is true (and good thinking).
  3. Aug 17, 2017 at 7:05 PM
    #83
    Comb
    Comb Known Member
    Sadly, I have a short bed, so...
  4. Aug 17, 2017 at 7:07 PM
    #84
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I think people are overvaluing the ability to open the cover. A little planning ahead and it's no issue at all. And if you need the rack out of the way, it comes off in a couple minutes.
    TrueBlueTaco and Tacomamike mike like this.
  5. Aug 17, 2017 at 7:22 PM
    #85
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Hmmmmmmm
  6. Aug 17, 2017 at 7:24 PM
    #86
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    See post #84
  7. Aug 17, 2017 at 7:53 PM
    #87
    Tacomamike mike
    Michael
    Got it...pretty easy to adapt in any situation.
    But someone will figure this puzzle out .
    Got to hit the bed early I have a kayak loaded and a couple of fly rods that need a few trout to hit them tomorrow :)
    Small hike in :)
    On the off chance I fall asleep.
    Goodnight all :).
    On the big chance that does not happen :). See you in a bit .
    Dryfly24 and KB Voodoo[QUOTED] like this.
  8. Aug 18, 2017 at 3:24 AM
    #88
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Guess it depends on situation. When I order I'll be getting the brackets anyways to try it out. Most of my stuff is in totes so it's not too much of an issue. But small items might end up in the back and be a bitch to get lol. I do have pretty long arms so might not be an issue. Time will tell
    And I do have a short bed
    Dryfly24 likes this.
  9. Aug 18, 2017 at 3:28 AM
    #89
    Tacomamike mike
    Michael
    Here's an idea :) get a bed slide ! Poof problem solved. Even for small items in back. Plus another mod !
    Joe23[QUOTED] likes this.
  10. Aug 18, 2017 at 3:37 AM
    #90
    Tacomamike mike
    Michael
    Lol hey joe it's pretty early to be up .
  11. Aug 18, 2017 at 4:49 AM
    #91
    VirusCage
    VirusCage [OP] Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Gaff hook...done
    KB Voodoo likes this.
  12. Aug 18, 2017 at 5:09 AM
    #92
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I use the factory bed extender, flipped inside the bed, to act like a cargo divider. Small stuff stays right near the tailgate. Bigger stuff can then be put on the other side of the extender, closer to the cab.
  13. Aug 18, 2017 at 5:11 AM
    #93
    VirusCage
    Bruce
    Allison Park, PA
    I should have asked this earlier. But how is the clearance with the front of the rack and the third brake light?
  14. Aug 18, 2017 at 5:15 AM
    #94
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There's a good amount of space between the two, so it's still visible.
    VirusCage[QUOTED][OP] likes this.
  15. Aug 18, 2017 at 5:23 AM
    #95
    VirusCage
    Bruce
    Allison Park, PA
    Looks like I will not cancel then!
  16. Aug 18, 2017 at 5:41 AM
    #96
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Just keep in mind though. Once you throw a RTT on it..third brake is cover. Not Voodoo issue but user preference of sleeping on hard ground or higher ground ;-). I personally like sleeping comfortably when camping so I chose to get RTT knowing that third brake light will be covered. I have attached a pic of my setup for you to see.
    Tacomamike mike and Jeepnick like this.
  17. Aug 18, 2017 at 5:51 AM
    #97
    VirusCage
    Bruce
    Allison Park, PA
    Thanks for the picture. I can always add a temporary light to the rack and plug into the hitch plug when the 3rd brake light is covered by kayaks, tents, what have you. I just want to leave the rack on at most times, so just wanted to be sure it wasn't covered at all times
    gargamel05[QUOTED] likes this.
  18. Aug 18, 2017 at 10:48 AM
    #98
    Joe23
    I thought of that...but damn are they pricey. plus then I'd sacrifice some height and I can already barely close the cover with my cooler lol
  19. Aug 18, 2017 at 10:49 AM
    #99
    Joe23
    bruh
    I'm up at 4 30am for work haha.
  20. Aug 18, 2017 at 10:50 AM
    #100
    Joe23
    even with the tall one?
