bed raid problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by turfdawg04, Jan 16, 2012.
  1. Jan 16, 2012 at 8:14 AM
    turfdawg04
    turfdawg04 [OP] New Member
    Alabama
    '10 Taco PR
    Hey guys, im new to the board. I have a 2010 Taco, and i recently installed a Access TonnoSport cover. The problem i have encountered is, the frame rail for the cover sits directly on top of the rail for the tie-down cleats. Now there isn't enough clearance for the cleats to slide back on to the rails. Was curious to know if anyone else has run across this and came up with a functional alternative. Thanks for any feedback.
  2. Jan 16, 2012 at 8:16 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Welcome buddy - You'll probably want to get this moved to the 2nd gen forum.
    I had the same issue with my access low rider cover. I sold my big cleats, and got the mini cleats from the dealer. You can find them on ebay too.
    Otherwise, I think you cans till use them on the back rail closest to the cab if you have a use for that.
  3. Jan 16, 2012 at 8:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thread moved. Welcome to TW!
  4. Jan 16, 2012 at 8:17 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Welcome to TW!
    and sorry can’t help about the cleats. i don’t have a cab or cover at all. i “THINK” i saw wear come up with some idea. but idk or wear to find it. maybe search on here.
  5. Jan 16, 2012 at 11:50 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    can't really help, but this is one of the main reasons i bought the access roll-up... full use of the bed rails if needed.
  6. Jan 16, 2012 at 1:02 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    welcome to TW :wave:
  7. Jan 16, 2012 at 1:08 PM
    darrmill
    darrmill Well-Known Member
    MA
    11 MGM DC SB
    Pop N Lock, Weathertechs, Viper remote starter, Intermittent wiper switch, devil horns, Access rollup tonneau, Wet Okoles, Rocky Mounts, EGR vent guards
    I have an Access Rollup and there's just enough clearance to use the cleats. I was debating between that one and a different Access model (low rider, I think). Bought it from truckalterations.com and the salesman on phone said they always suggest the Rollup for that very reason. Not sure about the Sport, but the Rollup looks like it sits the same way. Slants up to just above the bed sides.
  8. Jan 17, 2012 at 3:38 AM
    turfdawg04
    Alabama
    '10 Taco PR
    yeah, my TonnoSport is a roll-up also, but there just isnt enough clearance for the cleats, and it looks like that might still be an issue with the mini cleats as suggested earlier in the thread.
    Anyways, sorry for posting in the wrong spot, and thanks for the suggestions, i will keep looking.
