Bed rail or molle storage options for fuel and water
Discussion in '4th Gen. Tacomas (2024+)' started by desertrun, May 18, 2025.
  1. May 18, 2025 at 5:11 PM
    desertrun
    desertrun [OP] Member
    What
    2024 tacoma
    Let’s start this by letting everyone know I don’t want to run rotopax. They need maintenance, cost a ton and not a fit for my plans.
    I’d like to know if anyone is using the bed rails or a molle panel setup to mount extra water/gas cans in the bed. I need it low enough to fit under a tonneau as well.
    I’ve seen some options but I don’t want to stop 400+ and hope it works if someone else has a system I am not aware of that will fit my
    Purpose.
  2. May 18, 2025 at 5:38 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Pretty simple. A center molle panel with containers and straps of your choice. A five gallon gas and five gallon water can should fit under your cover. After wrestling with a five gallon water tank during my last trip, I am ditching it for two Dometic three gallon water jugs to spread the workload and carry a little more water. That space to the right has room for a five gallon jug if you choose.
    https://www.dometic.com/en-us/outdo...vMYII4cTk5-Nw8qrgB8TolmngZSZmar8aArgzEALw_wcB
  3. May 18, 2025 at 7:03 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    RotoPax need maintenance?! How? How are they different than any other plastic gas can?
  4. May 19, 2025 at 12:33 PM
    Weap0nR
    Weap0nR Well-Known Member
    SK
    AZ
    2024 TRD O/R Ice Cap
    check out rago fabrications. This is what I put in my truck and just lowered the bracket with the extender. Using rotopax but it should work for whatever you have in mind.
    desertrun[OP] likes this.
  5. May 20, 2025 at 5:01 AM
    desertrun
    What
    2024 tacoma
  6. May 20, 2025 at 6:38 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
