Bed Rail T-nuts- OE Toyota PN?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve_P, Dec 29, 2024.
  1. Dec 29, 2024 at 12:26 PM
    Steve_P
    Steve_P [OP] Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I'm looking for the Toyota PN for the bed rail T nuts. I know there are a million people selling them online with a 3/8-16 thread, but I want to keep the OE thread size- M8?; and for whatever reason, apparently no one makes them. I don't want to change hardware and carry a dedicated socket for two stupid bolts.
    So, does anyone know the Toyota PN for this? I probably spent 30 minutes looking for it online on various OE parts diagrams and found the rails, and hardware, but not the hold down rings or T-nuts. I just need the T-nuts.
    TIA!
  2. Dec 30, 2024 at 2:37 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
  3. Dec 30, 2024 at 11:01 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    As far as I’m aware Toyota has never made OEM t-nuts for the rails. It’s all aftermarket.
  4. Dec 30, 2024 at 3:20 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Look in here under bed
  5. Dec 30, 2024 at 3:26 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
  6. Dec 30, 2024 at 6:22 PM
    Steve_P
    TN
    I bought my truck new, there weren't any dealer additions, and only three factory options. It came with a large plastic D shaped tie down on each side that you could slide up and down the rail, moving the T-nut with it. It locks in place with a center plastic thumb screw that tightens an integral steel screw into the T-nut, which has an M8 thread. Was this not a factory part? If this was common aftermarket in the US, I'd think there'd be no issue with finding an M8 threaded one on someplace like Amazon or Ebay.
  7. Dec 30, 2024 at 6:31 PM
    Steve_P
    TN
    Thanks. I'm a huge fan of McMaster, but before I spend ~$10 each on them I may just modify what I made, which is a 1" wide X ~1" long, X .25" thick piece of steel bar with the M8 thread tapped in the center. I just need to weld a large nut, or similar, to the back to make it easier to start the fastener into the bar. I was in a rush when I made them last summer and didn't do it like I should've. They function just fine, but it's a PITA to start the fastener into them. It's not something I'm doing often, but it'll be worth the time or $20 to have something that works better.
  8. Dec 30, 2024 at 6:52 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    58461-04020-00
    05-2023 OEM TOYOTA TACOMA Bed Rail Tie-Down Cleats 4Pk
  9. Dec 30, 2024 at 11:31 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    You need them for the factory plastic tiedowns? Or are you using them for something else?
    If the former, do you know the tiedowns come out in one piece with the nut? You just have to rotate them the right way.
    NoOne likes this.
  10. Dec 31, 2024 at 8:55 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    The “nut” component of the OEM bed tie down cleat isn’t a separate part number. It’s all one piece. Toyota doesn’t sell just a bed rail nut by itself.
