Bed rail weight limit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yakas, Feb 12, 2015.
  1. Feb 12, 2015 at 8:21 PM
    yakas
    yakas [OP] Member
    Santa Barbara
    TDR Offroad White
    TBA
    I am building a solar hot water heater out of 3" schedule 80 and I want to mount it using the bed rails. Does anyone have any info on weight limitations for a single rail?
    thanks
  2. Feb 13, 2015 at 1:26 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not very much... :|
  3. Feb 13, 2015 at 1:34 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
  4. Feb 13, 2015 at 4:44 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    PVC or steel pipe?
  5. Feb 13, 2015 at 10:02 AM
    yakas
    yakas [OP] Member
    Santa Barbara
    TDR Offroad White
    TBA
    Thanks for the feedback
    PVC, but filled with water it could be up to 100lbs.
    side note, does anyone have info on the proper way to drill into bed liner?
  6. Feb 13, 2015 at 10:10 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It will support up to 100 lbs with ease.
  7. Feb 13, 2015 at 10:12 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's a composite bed, not a liner.
    If you drill into it, just make sure you reinforce from behind with a large, flat washer, so the head of your bolt doesn't tear through.
  8. Feb 13, 2015 at 10:15 AM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    I read somewhere they are rated for 200lbs tiedown.
    That being said I am not sure it would be very sturdy on one side. I would cross the bed, using one mount on each side then it would be plenty sturdy. They have quite a bit of flex on one side.
