Bed rails attachments.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricGagne, Sep 18, 2010.
  1. Jan 24, 2013 at 11:19 AM
    #201
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Hardware stores have big rubber fender washers. That's what I'm using.
  2. Jan 26, 2013 at 2:56 PM
    #202
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  3. Jan 26, 2013 at 5:46 PM
    #203
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks. We'll see how it goes with the wing-nuts, they seem pretty snug. If they do start to back off I'll try a lock washer or different nut.
  4. Jan 31, 2013 at 6:04 PM
    #204
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    I recently purchased a used cargo divider from a fellow TW member, but it was missing the hardware to attach to the bed rails. After some research in this thread and experimenting, this is what worked.
    All parts from Fastenal
    T slot nut 3/8"-16 x 9/16" x 5/8" part number 302932-130481
    This T slot nut is NOT tapped all the way through. The last 1/16" or so is not tapped.
    Allen head set screw 3/8" - 16 x 2-1/2" part number 25549
    5 arm star knob 2-1/4 diameter knob 3/8" -16 part number 11101414
    The knob is through thread knob with plastic at the end of the threads to prevent vibration from loosening.
    1. Put a couple drops of lock tite on the set screws and tightened them into the T slot nut.
    2. Drilled out the hole on the bracket to 25/64"
    3. On the back side of the bracket, there is a ridge of plastic the length of the bracket that fits in the bed attachment rail. I removed a section of the ridge the width of the T slot nut. I forgot to take the picture before I bolted the divider into the bed.
    4. The plastic insert on the knobs were too tight and had to run a 3/8 -16 tap through the threads and plastic. The tap removed enough plastic to allow the knob to be turned fairly easy but still be tight enough that the knob will not vibrate loose
    5. Put the T slot nuts with set screws in the bed rails, attached brackets and cargo divider.
    corgimas likes this.
  5. Jan 31, 2013 at 6:17 PM
    #205
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. Jan 31, 2013 at 6:21 PM
    #206
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Almost looks like OEM.
  7. Feb 1, 2013 at 5:32 AM
    #207
    markinvictoria
    markinvictoria New Member
    [​IMG][/IMG]I recently built a kayak rack for my 08 Taco...used 1/2 " carriage bolts for the mount. This is my first post with photo...wish me luck.
    Still trying to figure out how to post photo :confused:
  8. Feb 1, 2013 at 5:44 AM
    #208
    Sandman614
    Tim
    '06 SR5 Off Road
    looks like you missed something
  9. Feb 1, 2013 at 5:48 AM
    #209
    markinvictoria
    Thanks Sandman...how'd you post my photo?
  10. Feb 1, 2013 at 5:59 AM
    #210
    Sandman614
    Tim
    '06 SR5 Off Road
    pm'd
  11. Feb 1, 2013 at 6:16 AM
    #211
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Just ordered me rack real cheap in comparison of most. The rack comes in the just wanting on hardware. Pretty much doing the same thing except using t nuts.
  12. Mar 21, 2013 at 11:35 AM
    #212
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
  13. Mar 26, 2013 at 1:47 PM
    #213
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Just ordered all of this stuff. Once I get it I will post up some pictures.
  14. Mar 26, 2013 at 2:05 PM
    #214
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    interesting.
  15. Mar 26, 2013 at 2:11 PM
    #215
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I bought enough for 8 of them. If it goes well I think I will see how much interest there would be in people purchasing these all ready to go.
  16. Mar 26, 2013 at 9:29 PM
    #216
    MikeCB600F
    Plainfield, IL.
    I thought about making and selling them. I can put one together for less than $6. Shipping costs would not be worth it for a small order.
  17. Mar 26, 2013 at 9:45 PM
    #217
    zackbremer
    zackbremer Well-Known Member
  18. Mar 27, 2013 at 5:08 AM
    #218
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I could ship them out through my companies Fedex account. About $5-$6 dollars any where in the continental US. I think I am going to make some brackets also. Or I'll just make some for myself and tell people how to do it.
  19. Mar 27, 2013 at 7:57 AM
    #219
    Ds2199
    Ds2199 Active Member
    Golden, CO
    2013 TRD Sport
    OME 885 Coils, OME 9000 Nitrocharger struts, OME N182 Rear Shocks, Dakar Leaf springs, N-Fab steps, Katskins Leather seats, Weathertech floor liners
  20. Apr 2, 2013 at 7:18 PM
    #220
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    went with the T-Slot nuts from Grizzly; minimum $50 order to Canada, and reasonable shipping. (Its a heavy bag of nuts!) Now onto sourcing Quickfist clamps.
    and www.endroad.com - the Quickfist makers is simple to order from, and same pricing or less than Amazon/ebay.
