Bed rails attachments.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricGagne, Sep 18, 2010.
  1. May 29, 2013 at 12:21 PM
    #221
    rmcelwee
    rmcelwee Member
    Charleston, SC
    06 Prerunner SR5 Debadged
  2. Jun 5, 2013 at 8:25 AM
    #222
    xjoex
    xjoex Member
    Joe
    Colorado
    12 4Cyl 4x4 Regular
    ARE Cap
    My local fastenal did not have the t-nuts in stock, neither did the hardware store. But Rockymounts is local and had these in stock:
    Nice thing, you don't have to take the existing cleats out to put them in, they can fit in if you angle them through the bed rails.
    I bought conduit clamps, put wing nuts on them and sprayed them with plasti dip.
    I put a washer between the rail and the conduit clamp just for extra room, I sprayed those with plasti dip too.
    Works like a champ and clears the cap. Plus the plasti dip keeps the shovel from rattling.
    -Joe
  3. Jun 11, 2013 at 10:22 PM
    #223
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    sub'd for later reference
  4. Jun 11, 2013 at 10:45 PM
    #224
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    made my own slot nuts.
    and Teflon spacers.
  5. Jun 12, 2013 at 5:48 AM
    #225
    Infra
    Az
    Nice...I desperately need some for my new bed rack but don't know what size I need to purchase
  6. Jun 12, 2013 at 5:51 AM
    #226
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
  7. Jun 12, 2013 at 7:48 AM
    #227
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Me too.
  8. Jun 13, 2013 at 5:28 PM
    #228
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    well Done! definitely a fan of such excellent workmanship.
  9. Jun 13, 2013 at 7:04 PM
    #229
    bullaculla
    Da big big island!
    you should see the trailer harness relocate bracket in my gallery ;)
  10. Jun 30, 2013 at 10:30 PM
    #230
    pjo
    pjo The "Wet" Coast
    North Vancouver, Canada
    '10 TRD Sport
    Those look damn good!
    What did you make those out of those? The ones I got from Fastnel (black ones) are starting to rust...
  11. Jul 1, 2013 at 6:22 PM
    #231
    bullaculla
    Da big big island!
    LOL, mine are aluminum.
    Somebody told me that McMaster has stainless slot nuts that work for with rail system.
  12. Jul 1, 2013 at 7:52 PM
    #232
    Daveo
    Daveo Well-Known Member
    MN
    2013 DCSB TRD OR
    Any chance you'd do a run of aluminum t-nuts with the appropriate metric thread? I can't be messing around with this inch crap.
  13. Jul 1, 2013 at 8:26 PM
    #233
    bullaculla
    Da big big island!
    Sure. I also hate mixing hardware.
  14. Jul 1, 2013 at 8:32 PM
    #234
    Infra
    Az
    I'd definitely be in for some if you make a batch
  15. Jul 1, 2013 at 9:28 PM
    #235
    bullaculla
    Da big big island!
    That's a good deal! :eek:
    I'd rather buy that than make my own :D
  16. Jul 2, 2013 at 4:33 PM
    #236
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
  17. Jul 3, 2013 at 7:41 PM
    #237
    Padraigh
    Padraigh Member
    Western MA
    2005 DCSB TRD Sport
    10ft "C-channel" Unistrut cut to 5ft x2
    4 1in x 3/8in bolts, nuts and washers
    4 "A24" Strong-Tie angle brackets
    I'm not sure how strong this is going to be. I might swap out the C-channel unistrut for a full square version. Also, I gotta keep an eye on how the A24 angle bracket pieces stand up. Not bad for a first attempt.
  18. Jul 3, 2013 at 7:59 PM
    #238
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    ^^^^ That's pretty cool how much was the hardware?
  19. Jul 3, 2013 at 8:58 PM
    #239
    Padraigh
    Padraigh Member
    Western MA
    2005 DCSB TRD Sport
    I got the Unistrut from a buddy, but Home Depot has it for $16.10. The brackets are $3.15 each, $4 or so for the bolts, nuts and washers. Plus a can of bedliner spray paint for $8 (which I haven't done yet).
    $40 plus tax seems about right.
  20. Jul 25, 2013 at 1:43 PM
    #240
    BrianJayAZ
    BrianJayAZ New Member
    Jay
    Mesa, AZ
    2010 Sport Package 4x4
    I found a great solution by ordering the T-slot nuts only (8 for $20) from JP Metal Fabrication "Hook Up" product: http://www.jpmetalfab.com/products.html
    I contacted the company by email and was able to order 8 billet aluminum t-slot nuts that are light weight and are perfect for the rail. They are slightly longer than the gap in the rail and easily clear the bolt holding the track. This did not include the bolts but I found perfect bolts at Home Depot.
