Bed rails attachments.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricGagne, Sep 18, 2010.
  1. Feb 23, 2015 at 6:17 AM
    #381
    ThomasMore66
    Dallas/Fort Worth & Durango
  2. Feb 23, 2015 at 7:59 AM
    #382
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Dont know yet, just ordered them. Will need to fab hooks and etc to go between the knob and rail. The problem could be busting the knob off when something is strapped down. I think the best way would be to drill and tap an aluminum or stainles disc and set a stud using thread locker. Will probably make a few of those too.
  3. Mar 8, 2015 at 9:04 AM
    #383
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  4. Mar 20, 2015 at 8:36 PM
    #384
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I want to add to this thread. As many on here have done, adding a tonneau cover can ruin the rail system so I came up with my own cheap solution.
    I picked up these Reese anchor points from Wal Mart for $2.98 each. I took the steel plate and cut it down to fit inside the rail. I didn't take time to get measurements, just cut them and fine tunned with my grinder. Cut the bolt and the rubber piece down to shorten the whole assembly and had to trim off the top plate to fit under the rail from my tonneau and done. Seems to work great so far and cheap too.
  5. Mar 20, 2015 at 8:38 PM
    #385
    TacoDawgfan
    Georgia
    Sorry that I can't figure out how to post multiple pics from my ipad so here are more.
  6. Mar 20, 2015 at 8:40 PM
    #386
    TacoDawgfan
    Georgia
    And last.
    I can still easily loosen to move these around as needed.
  7. Mar 21, 2015 at 1:13 PM
    #387
    Bennersj
    Bennersj Well-Known Member
    Scott
    Lehigh Valley, PA
    TRD Sport Never Ending Project
  8. Apr 1, 2015 at 11:26 AM
    #388
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
  9. Apr 1, 2015 at 11:32 AM
    #389
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    MikeCB600F likes this.
  10. Apr 1, 2015 at 11:46 AM
    #390
    ThomasMore66
    Bullaculla has them reasonably priced. I just ordered 10 tapped 3/8",16 and it was $45 from HI to TX. I'll get knobs/bolts as I need them.
  11. Apr 1, 2015 at 11:58 AM
    #391
    gimmeajo
    Zander
    '13 DCSB 4WD TRD OR
  12. Apr 1, 2015 at 12:26 PM
    #392
    TacomaMike37
    13' DCLB MGM
    What knobs were you thinking about using with them?
  13. Apr 1, 2015 at 12:38 PM
    #393
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm currently developing a bike carrying system that uses the side rails. Since I can't find an off-the-shelf product that will fit inside the rail exactly the way I want, I will be producing my own.
    They will be 3/8" thick x 1" wide x 2" long. The outside shape, with radiused corners, will be CNC plasma cut. I will drill and tap them for 1/2"-13 thread.
    I considered aluminum, but I need as much strength as I can get for my application, so they will be made from hot rolled steel.
    Since I'm making them anyway, they will be available for sale.
    Wallbright likes this.
  14. Apr 1, 2015 at 12:56 PM
    #394
    gimmeajo
    Zander
    '13 DCSB 4WD TRD OR
    Just bolts, going to mount shovel & axe behind cab. Got some extras for future unknowns.
  15. Apr 1, 2015 at 7:05 PM
    #395
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    When I bought mine then posted the Amazon link they had a lot of them in stock. Maybe a machine shop somewhere sucked them all up but I bet it was the power of TW. Should have ask them to put me on commission :)
  16. Apr 12, 2015 at 10:58 AM
    #396
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
  17. Apr 12, 2015 at 11:52 AM
    #397
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    Just a heads up on Fastenal - it took them three tries to get me the correct T-slot nuts. I've now got 7 that are the wrong thread sizes and 1 that is the wrong thread and wrong deminsions (all were in incorrectly labelled bags). Fastenal was great to deal with, even if they just kept sending me things until they got it right. Hahaha
    Moral of the story, double check the things you receive from, Fastenal.
  18. Apr 12, 2015 at 11:57 AM
    #398
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Honestly, between their shipping practices, in store help and customer service, I have little interest in doing business with them in either of the 2 stores locally. Seems to be a trend.
    and...great thread, Thanks!
  19. Apr 12, 2015 at 12:16 PM
    #399
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  20. Apr 12, 2015 at 12:17 PM
    #400
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    I've purchased mine through Zoro tools.
