Bed Realignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GLOCKAMOLE, Aug 27, 2010.
  1. Aug 27, 2010 at 12:37 PM
    GLOCKAMOLE
    GLOCKAMOLE [OP] Member
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    Window tint, XM, Tri-fold Tonneau cover, side steps.
    So some jackass rear-ended me a couple weeks ago. His insurance is issuing me a check for the damages, which are minimal. Among the few things wrong is the shift in my bed from the impact. There is appx. 1/2 inch difference in gap between the bed and the cab on each side. Do I simply loosen the six torx bolts in the bed and shift it, or is there a more in depth solution? I would like to fix it myself and pocket the money, if at all possible. Thanks in advance.
  2. Aug 27, 2010 at 12:43 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Yep that is all you do. Make sure you have a solid torx bit and not the one with a hole in the middle. The torx size is T55.
  3. Aug 27, 2010 at 12:49 PM
    GLOCKAMOLE
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    Awesome. Thank you!
  4. Aug 27, 2010 at 1:07 PM
    S.B.
    Sean
    I had to do mine about a month ago. Its really easy, hardest part is getting the bolts loose.
  5. Aug 27, 2010 at 1:09 PM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    I actually have a similar issue (except that mine was caused by an owl flying into the side of my truck....) but I'm shifted from side to side.
    Thanks for the info!
  6. Aug 27, 2010 at 1:34 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    How big was the owl? :eek:
