Bed removal for fuel pump replacement — look fors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tguil, Apr 13, 2021.
  1. Apr 16, 2021 at 6:30 AM
    #41
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
  2. Apr 16, 2021 at 8:08 AM
    #42
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Thanks California.
  3. Apr 16, 2021 at 8:50 AM
    #43
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    ^ This. And one I came within a 1/4” of drilling through a couple of months ago when I installed an in-bed tool box :eek:
    tonered[QUOTED] likes this.
  4. Apr 16, 2021 at 8:51 AM
    #44
    Kev250R
    Kevin
    Orange, So.Cal.
    All of us here in the Golden State hope you’re enjoying your clean air :D
    uurx, tonered and RCBS[QUOTED] like this.
  5. Apr 16, 2021 at 8:52 AM
    #45
    RCBS
    Gas cans are spot on too bud. Thanks again! :mad:
    :p
    Kev250R[QUOTED] likes this.
  6. Apr 16, 2021 at 8:56 AM
    #46
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yikes! Good on you for missing it.
    I save a person from nicking the filler neck before they installed a tonneau drain. If ever there was a need for an actually useful warning sticker or two . . .
  7. Apr 16, 2021 at 9:04 AM
    #47
    Kev250R
    Kevin
    Orange, So.Cal.
    I know what you mean. I’m normally more careful then that but I was in a hurry, wanted to re-use the existing holes in the toolbox and just eyeballed it real quick. I got lucky that’s for sure!
  8. Apr 16, 2021 at 9:07 AM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It certainly isn't a typical location for a charcoal canister, but that probably has something to do with the returnless system.
  9. Apr 16, 2021 at 9:10 AM
    #49
    81shark
    81shark Well-Known Member
    They early ones had the pedal cut. Later ones received a replacement. Mine is still open and outstanding. Pedal was never an issue, idiots double stacking mats was.
    Sorry OP
    Personally, i wouldn't care if they lifted the bed. Then again, i received the replacement frame service, so my entire truck was lifted off.
    michael roberts likes this.
  10. Apr 16, 2021 at 9:10 AM
    #50
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    With all the stuff attached to the fuel tank, I'd say it's almost easier to remove the bed for this job.
    Skydvrr and Kev250R like this.
  11. Apr 16, 2021 at 9:13 AM
    #51
    Kev250R
    Kevin
    Orange, So.Cal.
    T
    The worst one I’ve had to deal with was a Charcoal Canister R/R on an ex GF’s early 2000’s Lexus ES300. Bonus that the car was lowered so it was even harder to access. That one sucked.
  12. Apr 16, 2021 at 9:30 AM
    #52
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No fun there. I looked through the different fuel pump recalls. Only a couple looked easy with rear seat access. I'd hate to deal with the tank area on any modern car.
  13. Apr 16, 2021 at 9:58 AM
    #53
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Keep that recall open as long as you can. That recall was dumb.
    michael roberts and RCBS like this.
  14. Apr 16, 2021 at 11:48 AM
    #54
    RCBS
    Fuggers cut my pedal when they swapped frames. I made the service writer physically write it down in front of me not to. Noted that my husky liners could no way trap the pedal and that the tacomas TBW assembly was made by a different manufacturer than the ones at issue during the 'Unintended acceleration' debacle. What a shite show that was.
  15. Apr 16, 2021 at 11:52 AM
    #55
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Probably a misinformed service writer thinking fuel pump access would be the same as a Camry...
    Kev250R likes this.
  16. Apr 21, 2021 at 12:29 PM
    #56
    tguil
    tguil [OP] Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Update from OP: Tech ended up dropping the tank (1/4 full). No lifting of bed. Two hour job including lube, oil filter, safety check. (Had a 2021 Tacoma loaner. Nice truck. No POS shifting issues.)
    rsimi72, tonered, Kev250R and 2 others like this.
  17. Apr 21, 2021 at 4:16 PM
    #57
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Sounds good O.P.
  18. May 26, 2021 at 1:37 PM
    #58
    Teamrivers
    Teamrivers Well-Known Member
    Brent
    Atlanta, GA
    2018 TRD Off Road 4x4 DBL 5.5
    Diamond Back HD, full interior light change, DiodeDynamics main lamps, Caliraised amber fogs & ditches, Caliraised 25 Degree sliders no plate, SSO slimline front bumper w/ 20" LED Smitty Gen3 winch, Barricade rear bumper with rear in bumper lights from SuperbriteLEDs, Budbuilt rock 2 plates with rerouted exhaust, Method 306, 295 Ridge Graps. OEM Kings tuned from Filthy, Deaver Exp 1, SPC UCAs, 5.29 diffs. Dash mounted 1/4 threaded accessory plate. And a TRD Pro grill...assuming I qualify for pro status.
    Anyone aware of service departments rejecting the replacement of the fuel pump on the basis of modifications? To include VF tuning fuel management, rear seats removed with deck and heavy electrical from the double cab through to the bed including heavy grounding wire to the neck bracket, tank and undercarriage armor and a host of electrical runs and connections. No way in hell they can remove my bed or even lift it up with a cab molle and dual air compressor system mounted under the tonneau. I "think" they can drop the tank but maybe I need to pull the armor plate beforehand. I'm scheduled for June 4th so need to prepare it beforehand.
  19. May 26, 2021 at 1:44 PM
    #59
    5nahalf
    Erik
    Minnesota
    The repair instructions are to remove the tank. So they can not say anything about the cab or bed mods. They may charge you for removal of the skid though, so I recommend removing that before you bring it in.
    davidstacoma likes this.
  20. May 26, 2021 at 1:45 PM
    #60
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    They did mine by dropping the tank, call and ask. I bet they’re going to say to just remove the skid but that should be it.
