Bed removal pictures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JanBoothius, Apr 14, 2011.
  1. Apr 14, 2011 at 3:05 PM
    JanBoothius
    JanBoothius [OP] Taco abuse specialist
    Jan (Pronounced Yon)
    Salt Lake City, UT/Upstate New York
    '10 TRD Off Road Access Cab, 6 speed
    OME lift, 886 coils, Dakars w/AAL ARB front bumper, Warn M8000 winch Toyo Open Country MT 285/75R17 (34) Leer 180CC cap etc etc etc $
    Hey,
    After searching high and low (TW and the internette en generale), I could not find any pics of bed removal on a 2nd gen Tacoma.
    If anyone has links/pics/any info whatsoever, I'd love to bear witness to it!
    Thanks!
  2. Apr 14, 2011 at 3:08 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i seem to remember coming across some descriptions and maybe pics when i was searching on fuel pump removal...some suggested to move the bed to access the top of the tank and claimed it be easier than removing the tank...i ended up dropping the tank...bout the most help i can give
  3. Apr 14, 2011 at 5:54 PM
    JanBoothius
    Hmm, I couldn't find anything by searching along those lines either.
    Anyone else?
  4. Apr 14, 2011 at 6:07 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  5. Apr 14, 2011 at 6:09 PM
    1700OW
    1700OW Well-Known Member
    PreRunner to be converted to 4x4
    ..I have a list of many things.
    Are you talking about the whole bed? or just the bed insert (the composite)?
  6. Apr 14, 2011 at 6:48 PM
    tex
    tex Well-Known Member
    Aaron
    Arlington, TX
    2015 4 Runner Trail
    It is really easy to remove. Undo the bed bolts, unplug the taillights (the housing should stay with bed), remove tailgate and once the bed is lifted a little feed the gas filler neck through the hole or it might unhook.
    I have helped take off a few chevy beds to replace fuel pumps so it should be pretty much the same process. Oh and the Chevys had a ground strap from the bed to frame so look out for that.
  7. Oct 4, 2016 at 7:52 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    did you ever take your bed off? just wondering as i'm thinking about pulling my bed off to drill a bunch of holes in it for attachment points for gear. (high lift, shovel/axe mount/bin and cooler tie-downs...) Seems like by the time i try to get nuts and washers up in around all the stuff under it i'll have spent more time (and probably been unsucsessful) than just taking the bed off....
