Bed Removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by JJ04TACO, Feb 9, 2016.
  1. Feb 9, 2016 at 12:07 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I was looking for some insight on how to remove the bed from a DC Taco and couldn't find anything. I looked under the chassis and located only four bolts, which seems about right for the short bed. Can anyone confirm this as accurate?
    I don't really need to remove the bed so much as gain access underneath to assist in mounting some L Track. The bolts will need to be drilled and nuts tightened. So removing wires may not be necessary but I may have to loosen the filler neck on the fuel tank to shift things around a bit...
  2. Feb 9, 2016 at 5:17 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Regular beds have 6 bolts. 2 up front, 2 behind wheels, and 2 at the back (through the frame). Not sure on the DC.
    Filler neck isn't bolted to the bed, just slides out of the rubber grommet. Taillight wires are the only thing connected to bed besides the bolts.
    Edit: just checked my DC. They are the same, 6 bolts
  3. Feb 9, 2016 at 5:25 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Exactly. It may look intimidating, but it is really quite easy.
    The first time I did it, my 110 lb wife helped me take it off the frame. Take the tail gate off to make it lighter yet.
  4. Feb 9, 2016 at 6:32 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Thanks, I'll look harder to locate the two missing bolts. The tops of which are covered by the bedliner...
  5. Feb 9, 2016 at 6:34 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    They don't come up through the bed. It's all underneath.
  6. Feb 9, 2016 at 6:37 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Good to know...I'll just look harder then. ;)
