Bed Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kantishna, Jun 27, 2019.
  1. Jun 27, 2019 at 9:13 PM
    Tbinion8990
    Tbinion8990 Member
    Tyler
    2017 Sport MT Black
    Finally someone else who uses their truck to work! Kuddos, they are trucks , use em boys
  2. Jun 27, 2019 at 9:17 PM
    Coyote501
    Coyote501 Well-Known Member
    Ohio
    2019 Barc Red AC
    Should be a good work truck. Tacomas' are tough sons a bitches. Might look like shit after a couple years, but should run forever.
  3. Jun 27, 2019 at 9:21 PM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Nor have I yet to see a pallet fit in a Taco, or a picture.
    Stocklocker[QUOTED] likes this.
  4. Jun 28, 2019 at 12:10 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The dummy frontend loader operator at a site I worked at dumped a load of snow into his buddy’s Ford pickup to take home to his kids, he had to flatbed his truck off the mountain with the bed sides pushed out. :crazy:
  5. Jun 28, 2019 at 3:20 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I have not managed to melt mine with an errant torch, camp stove, or soldering iron. It is more akin to fibreglass than plastic. It’s not a melty material, but it will burn if you try.
  6. Jun 28, 2019 at 4:38 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    About 10% of the time I use the tacoma, it is picking up a pallet from the trucking depot.
    A piece of 1/2 or 3/4 plywood is perfect for me in the bed to load pallets in with the forklift. Bed itself is too slick and easy to gouge with an errant nail. Bed mat has too much traction and is too soft, nails catch.
    A sheet of plywood is just goldilocks....
    I just use a 4x8 sheet, notched for the wheel wells and cut to length. (It is the same sheet I have used for like 6 years, had in the first gen, so the wheel cutouts aren't perfect, but who cares.)
  7. Jun 28, 2019 at 5:00 AM
    msapers
    msapers Well-Known Member
    Scott
    Los Angeles
    2017 TRD Off Road DCSB V6 MT
    OP, why not make drop in bed floor out of diamond plate steel (or aluminum to save weight)? then you could just replacde that when it needs replacing. Just cut it to match the beed floor, drill holes where all the current bolts and tie downs go, drop it in and bolt it down. Done.
    psmura likes this.
  8. Jun 28, 2019 at 9:59 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Check Craigslist, I see beds offered up for about $1,000 here in Oregon.
