Bed roll bar? yes or no?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Prerunner2511, Jan 7, 2012.
  1. Mar 14, 2019 at 10:06 AM
    #61
    Rpurdy2.7
    Rpurdy2.7 Member
    Bobby
    2011 2.7 Reg Cab Tacoma 4x4 5 speed
    285R16 bfg all terrain tires Guardian level 8 wheels 3" toytec lift Tuff country uca's LCE header K&N cold air intake Aries grill gaurd Sterling equipment roll bar KC's Ionic tonneau cover Tow package with brake controller
  2. Mar 14, 2019 at 12:03 PM
    #62
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Most of those "roll bars" available aren't actually roll bars, they're "light bars" or something else.
    A roll bar denotes that it is integrated into the frame.
    mjp2 likes this.
  3. Mar 14, 2019 at 12:19 PM
    #63
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Cool truck, they don't make the 4cyl 4x4 manual anymore. let alone a reg cab like that.
    love those 80's trucks with the solid front axle
  4. Mar 14, 2019 at 4:47 PM
    #64
    ImperialJade1stGen
    ImperialJade1stGen Member
    Tom
    1999 SR5 Ext Cab 4C 5M 4WD
    Lift and Level, 31.5" Tires, Swapped wheels with 2nd Gen 4Runner
    Added one to mine and love it. GoRhino bed bar kit off of Amazon. Install was a bear, fair warning. Haven't decided yet if the lights are going to go on top. Open to suggestions.
  5. Mar 14, 2019 at 4:51 PM
    #65
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Unless your Michael J Fox, I say No
    99cVooDooTaco likes this.
  6. Mar 15, 2019 at 8:37 AM
    #66
    chrispchicken9
    I think it looks nice, does it actually go through the bed into the frame though?
  7. Mar 15, 2019 at 8:39 AM
    #67
    Rpurdy2.7
    Rpurdy2.7 Member
    Bobby
    Looks bad ass, definitely throw some kcs on there. I doubt it goes to the frame, as mine does not... It's just roll bar sounds cooler than light rack
    Lukass likes this.
  8. Mar 15, 2019 at 8:41 AM
    #68
    chrispchicken9
    Yea a legit roll bar into the frame would be nice. And a lot safer too.
    And then you could throw some long travel suspension on it for the rear haha
  9. Mar 15, 2019 at 8:43 AM
    #69
    Indy
    Indy Master of all I survey.
    FWIW lights mounted overhead don't work all that well. I've had them on trucks for 20ish years both halogen through led. They do a great job of making your hood super bright and highlighting how dirty your windshield is. If a place to mount lights is really what you're after, go with an aftermarket bumper or a bull bar.
    mjp2 likes this.
  10. Mar 15, 2019 at 8:45 AM
    #70
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    I like the light bar look a whole lot...
    pat's taco and Cudgel like this.
  11. Mar 15, 2019 at 8:46 AM
    #71
    BigMacMcCoy
    Braedon
    Vienna, VA
    IDK man, mine throw a ton of light downrange. If you tilt them down too far, yeah all they would light up is your hood. I use them for distance lighting, and use the from bumper lights for closer range.
    But what do I know, I'm only running 8 HIDs with something like 40k lumens total IIRC.
  12. Mar 15, 2019 at 8:56 AM
    #72
    Indy
    The only way to keep them from hitting the hood is to extend the bar forward (most light mounts you see do that to help) and also run a bottom shield, which most don't. By the time you angle them up far enough to stop kicking off the hood the people on the ISS will be bitching at you because they're trying to sleep.
    My last taco I ran a bar on the bumper and an overhead. I used the bumper all the time, worked great. The overhead I really only used when I was in the mountains and the twisties. The light spectrum the LED's kick out make deer eyes light up from 100 miles away and a deer will cannonball off a cliff if they think they can get in front of you :laugh:
    During a snow storm, OMG beyond useless. You go from 10 feet of visibility to 0. The same with dust. But again the bumper bar, mounts lower than the headlights, punches through both fairly well.
    Back in the halogen days my truck had 6 lights on the rollbar (real actual roll bar), a pair on the A pillars, and 4 on the bumper. I don't recall the lumens but I ran 130w bulbs in all of them. I used spots in the center of the bar, more directional than others and worked ok.) Then floods on the outside pointed about 45 degrees out to light up the side trail. I used to kick out enough light that trees would burst into flame as I drove by :laugh: I was always at the front of the line for trail rides to say the least.
  13. Mar 15, 2019 at 9:32 AM
    #73
    BigMacMcCoy
    Braedon
    Vienna, VA
    I've got the same split of spots in the middle and spreads on the sides.
    Mine really don't have an issue hitting the hood or roof. Then again they are about 9" tall and the light bar is even with the roof, so they sit up off the roof a bit. There is some glare on the roof, but definitely none on the hood. Mine are all pointed straight forward, not even angled up.
    I definitely don't turn them on when on the roads, that would be dangerous.
  14. Mar 15, 2019 at 9:42 AM
    #74
    Clearwater Bill
    Billy
    Largo Florida
    As long as you know it's not really a roll bar, and you like it, do it.
    It's the boy racer equivalent to a level lift. Looks. Only.
    Unless automatic weapons are mounted to it. Along with a support system for the trigger man. :D
    BigMacMcCoy likes this.
  15. Mar 17, 2019 at 8:00 PM
    #75
    99cVooDooTaco
    99cVooDooTaco Member
    2019 VooDoo Tacoma
    I was looking around at the GoRhino and Black Horse ones.. I like the look of the powder coated tubing. Any opinions on either company??
  16. Mar 17, 2019 at 8:13 PM
    #76
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
  17. Mar 17, 2019 at 8:17 PM
    #77
    soggyBottom
    soggyBottom Well-Known Member
    There is a guy down the street with one on a 3rd gen. It has a laser cut star on the bars and a big black sticker on the side of the bed that says us army edition. I think it looks super tacky.
  18. Mar 18, 2019 at 3:04 AM
    #78
    ImperialJade1stGen
    Tom
    I have the goRhino powder coat black kit installed on mine and have so far been really pleased with it. Good fit, good finish. Mine is a garage queen now though, so I can't speak to whether it holds up to everyday use without loosening or rattling around back there
    99cVooDooTaco[QUOTED] likes this.
  19. Mar 18, 2019 at 6:08 AM
    #79
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    If I were going to build one, I'd use this style, but extend the rails all the way to the back corner of the bed. I had the rails on my 2002 Dodge 2500 and actually got a lot of use out of them for tie downs. I'd also add some hooks to the bottom and/or inboard sides of those long tubes for wrapping rope, hooking straps, etc.
    99cVooDooTaco and Taco critter like this.
  20. Apr 18, 2019 at 8:15 PM
    #80
    ehidal1
    ehidal1 Well-Known Member
    Katy, Texas
    2017 Tacoma TRD Sport
    Bump- Nice truck! What is the make/model of your roll bar? I like it.
