Bed Shell Bolt Torque
Discussion in 'Tonneau Covers, Caps and Shells' started by djtech, Sep 2, 2014.
  1. Sep 2, 2014 at 1:55 PM
    djtech
    djtech [OP] Active Member
    Anyone know what the bolt torque should roughly be for Leer or Century shells on our tacomas?
  2. Sep 2, 2014 at 1:59 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    not sure but I'll ask Leer next week when I pick mine up...
    I've had three other canopys in the past 20 years and always used "box end wrench snug" for torque.
  3. Sep 3, 2014 at 7:42 AM
    Pigpen
    Dan
    Northwest Montana
    I went with tight enough to bend the bolts - the piece that goes in the channel has a little wiggle when loose. This has kept mine from shifting.
